coq-club - Re: Partial reflection?
chronological Thread
  • From: "Cuihtlauac ALVARADO - STAGIAIRE A FT.BD/CNET/DTL/MSV" <Cuihtlauac.Alvarado AT cnet.francetelecom.fr>
  • To: Freek Wiedijk <freek AT cs.kun.nl>
  • Cc: coq AT pauillac.inria.fr
  • Subject: Re: Partial reflection?
  • Date: Mon, 16 Aug 1999 18:04:01 +0200
  • Organization: France Télécom - Branche Développement - Cnet - DTL/MSV
Hi,
I'm working on reflection too. I have an --- experimental --- tactic which
might
be used as first step towards what you are aiming. Here comes an example :
(* Field.v *)
Require ListT.
Require Reify.
(* Target theory: Fields ---------------------------------------------------
Parameter A : Type.
Parameter A_Null, A_Unit : A.
Parameter A_Opp, A_Inv : A -> A.
Parameter A_Plus, A_Mult : A -> A -> A.
Parameter A_Plus_commut : (x,y:A)(A_Plus x y)==(A_Plus y x).
Parameter A_Plus_assoc : (x,y,z:A)(A_Plus x (A_Plus y z))==(A_Plus (A_Plus x
y)
z).
Parameter A_Plus_neutral_r : (x:A)(A_Plus x A_Null)==x.
Parameter A_Plus_invert_r : (x:A)(A_Plus x (A_Opp x))==A_Null.
Parameter A_Mult_assoc : (x,y,z:A)(A_Mult x (A_Mult y z))==(A_Mult (A_Mult x
y)
z).
Parameter A_Mult_neutral_r : (x:A)(A_Mult x A_Unit)==x.
Parameter A_Mult_invert_r : (x:A)~(x==A_Null)->(A_Mult x (A_Inv x))==A_Unit.
Parameter A_distrib_l : (x,y,z:A)(A_Plus x (A_Mult y z))==(A_Mult (A_Plus x y)
(A_Plus x z)).
Parameter A_distrib_r : (x,y,z:A)(A_Plus (A_Mult x y) z)==(A_Mult (A_Plus x z)
(A_Plus y z)).
(* Reification stuff -------------------------------------------------------
Parameter A_default : A.
Inductive fld : Set :=
  | f_Var : nat -> fld
  | f_Unit : fld
  | f_Null : fld
  | f_Inv : fld -> fld
  | f_Opp : fld -> fld
  | f_Mult : fld -> fld -> fld
  | f_Plus : fld -> fld -> fld.
Section Eval.
  Variable rho : (listT A). (* valuation *)
  Fixpoint f_eval [g:fld] : A :=
    Cases g of
      | (f_Var x) => (nth A A_default rho x)
      | f_Unit => A_Unit
      | f_Null => A_Null
      | (f_Inv g) => (A_Inv (f_eval g))
      | (f_Opp g) => (A_Opp (f_eval g))
      | (f_Mult f g) => (A_Mult (f_eval f) (f_eval g))
      | (f_Plus f g) => (A_Plus (f_eval f) (f_eval g))
    end.
End Eval.
With this stuff I can make a Coq session like that :
Coq < Load Field.
Blah, blah, blah...
Coq < Goal (x,y:A)(A_Opp (A_Plus x y))==(A_Plus (A_Opp y) (A_Opp x)).
1 subgoal
Unnamed_thm < Intros; Reify fld f_eval A A_default A_Unit A_Null A_Inv A_Opp
A_Mult A_Plus. Intros; Reify fld f_eval A A_default A_Unit A_Null A_Inv A_Opp
A_Mult A_Plus.
1 subgoal
  x : A
  y : A
   (f_eval (cons A y (cons A x (nil A)))
     (f_Opp (f_Plus (f_Var (S O)) (f_Var O))))
    ==(f_eval (cons A y (cons A x (nil A)))
        (f_Plus (f_Opp (f_Var O)) (f_Opp (f_Var (S O)))))
Unnamed_thm <
Here I get a goal with "field objects" which I might use the way I want. I'm
currently working on tools to automate & combine manipulations on those terms.
As you can see it's still very experimental since "Reify" should guess the
right
inductive data structure encoding "target" field terms and the associate
evaluation function.
A work in progress...
Cuihtlauac ALVARADO
France Telecom - Branche Developpement - Cnet - DTL/MSV/MFL
Bureau WF 907 - 2, avenue Pierre Marzin - 22307 Lannion Cedex - France
Tel: {+33|0} 2 96 05 32 73 - Mobile: {+33|0} 6 08 10 80 41
Fax: {+33|0} 2 96 05 39 45
