coq-club - [Coq-Club] Second order unification problem
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Second order unification problem
  • Date: Fri, 17 May 2002 13:54:21 +0100 (BST)
If I have a dependent type such as, for example, the following:
Inductive natvect:nat->Set :=
  empty:(natvect O) |
  cons:(n:nat;v:(natvect n))(item:nat)(natvect (S n)).
And I try to prove a simple theorem with an object of this type in the
goal, such as:
Lemma test:(w:(natvect O))(w=empty).
I would expect to be able to prove this by case analysis on w - there is
only one constructor which can give us a natvect O. However, Case,
Induction and NewInduction on w all give the following error message:
"Error: Cannot solve a second-order unification problem"
Is there another way to approach this problem?
Thanks,
Edwin.
To unsubscribe, mail
coq-club-request AT pauillac.inria.fr
Bug reports: http://coq.inria.fr/bin/coq-bugs
Coq-Club Archives: http://coq.inria.fr/mailing-lists/coqclub/
