- From: Solange Coupet-Grimal <owner-coq-club AT pauillac.inria.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Second order unification problem
- Date: Fri, 17 May 2002 15:57:33 +0100
- Organization: INRIA
Edwin Brady wrote:
> If I have a dependent type such as, for example, the following:
> Inductive natvect:nat->Set :=
> empty:(natvect O) |
> cons:(n:nat;v:(natvect n))(item:nat)(natvect (S n)).
> And I try to prove a simple theorem with an object of this type in the
> goal, such as:
> Lemma test:(w:(natvect O))(w=empty).
> I would expect to be able to prove this by case analysis on w - there is
> only one constructor which can give us a natvect O. However, Case,
> Induction and NewInduction on w all give the following error message:
> "Error: Cannot solve a second-order unification problem"
> Is there another way to approach this problem?
> Thanks,
> Edwin.
> To unsubscribe, mail
> coq-club-request AT pauillac.inria.fr
> Bug reports: http://coq.inria.fr/bin/coq-bugs
> Coq-Club Archives: http://coq.inria.fr/mailing-lists/coqclub/
-- Here is a way to solve your problem.
This is a piece of a file you can find in the users' contributions
(hardware).
I hope it will be useful.
Best regards,
Solange COUPET-GRIMAL
_____________________________________________________________
CMI-39, rue Frederic Joliot-Curie - 13453 Marseille Cedex 13
Tel : (33) 04 91 11 36 17
Require Export Eqdep.
Chapter ...
Variable A:Set.
Inductive d_list :nat->Set:=
d_nil:(d_list O)|d_cons:(n:nat)A->(d_list n)->(d_list (S n)).
Definition eq_list:=(eq_dep nat d_list).
Lemma empty_dep:(n:nat)(l:(d_list n))n=O->(eq_list O d_nil n l).
(Unfold eq_list ; Intros n l).
(Dependent Inversion_clear l; Auto).
(Intros H; Absurd (eq ? (S n0) O); Auto).
Save.
Hint empty_dep.
Lemma empty:(l:(d_list O)) d_nil=l.
Intros l.
Apply (eq_dep_eq nat d_list O).
(Apply empty_dep;Auto).
Save.
- [Coq-Club] Second order unification problem, Edwin Brady
- <Possible follow-ups>
- Re: [Coq-Club] Second order unification problem, Solange Coupet-Grimal
- Re: [Coq-Club] Second order unification problem, Bruno Barras
