- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Second order unification problem
- Date: Fri, 17 May 2002 17:17:49 +0200
- Organization: INRIA Rocquencourt (France)
Hello,
let me add a word on Solange's answer. Note that Eqdep introduces an
axiom, namely
Axiom eq_rec_eq :
(U:Set; p:U; Q:(U->Set); x:(Q p); h:(p=p))x=(eq_rec U p Q x p h).
You can prove your result without any axiom, because equality on nat is
decidable. Eqdep_dec proves a few lemmas about this. Here is a proof:
Require Eqdep_dec.
Require Peano_dec.
Lemma test: (v:(natvect O))v=empty.
Intros v.
Change v=(eq_rec ? ? natvect empty ? (refl_equal ? O)) .
Generalize (refl_equal ? O).
Change ([n:nat; v:(natvect n)](e:(O=n))v=(eq_rec ? ? natvect empty ? e)
O v) .
Case v; Intros.
Apply K_dec_set with p:=e.
Exact eq_nat_dec.
Reflexivity.
Discriminate e.
Save.
Best regards,
Bruno Barras.
Projet LogiCal - INRIA Rocquencourt
tel : +33 1 39 63 53 16
mailto:Bruno.Barras AT inria.fr
http://logical.inria.fr/~barras
To unsubscribe, mail
coq-club-request AT pauillac.inria.fr
Bug reports: http://coq.inria.fr/bin/coq-bugs
Coq-Club Archives: http://coq.inria.fr/mailing-lists/coqclub/
- [Coq-Club] Second order unification problem, Edwin Brady
- <Possible follow-ups>
- Re: [Coq-Club] Second order unification problem,
Solange Coupet-Grimal
- Re: [Coq-Club] Second order unification problem, Bruno Barras
