coq-club - Re: [Coq-Club] inductive and mutual inductive data types in Coq
chronological Thread
  • From: Benjamin GREGOIRE <Benjamin.Gregoire AT inria.fr>
  • To: Amy Felty <afelty AT site.uottawa.ca>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] inductive and mutual inductive data types in Coq
  • Date: Mon, 21 Oct 2002 18:37:36 +0200
Amy Felty wrote:
It doesn't use mutual induction, but it also does not give me an
induction principle as general as I need.  I get a warning "Ignoring
recursive call", and the induction principle Tree_ind is:
Tree_ind
    : (P:(Tree->Prop))
       ((l:(list nat); l0:(list Tree))(P (Node l l0)))->(t:Tree)(P t)
I'd like the induction principle that assumes P for each tree in l0.
Try this:
Inductive Tree:Set :=
| Node : (list nat) -> (list Tree) -> Tree.
Inductive forall [P:Tree->Prop] : (list Tree) -> Prop :=
 | FA_n : (forall P (nil ?))
 | FA_c : (t:Tree) (P t) ->
        (l:(list Tree))(forall P l) -> (forall P (cons t l)).
Lemma Tree_ind2:
   (P:(Tree->Prop))
       ((l:(list nat); l0:(list Tree))(forall P l0) ->
     (P (Node l l0)))->(t:Tree)(P t).
Intros P H.
Fix 1.
Intros t; Case t.
Intros.
Apply H.
Elim l0.
Constructor.
Intros; Constructor.
Apply Tree_ind2.
Trivial.
Qed.
Then you can use Tree_ind2 as follow:
Elim t using Tree_ind2.
Benjamin Gregoire
