- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Pattern matching while defining a type
- Date: Tue, 22 Oct 2002 15:01:05 +0200
Hi,
Does Coq permit me to do pattern matching on a type while defining
this same type?
What I'm trying to do (with version 7.2) is something like:
Inductive Example : Type :=
Example1: nat -> Example
| Example2:
let check = [e:Example]
Cases e of
(Example1 n) => (lt (S (S O)) n)
|(Example2 e p) => false
end
in
(e:Example) (check e)-> Example.
In the definition of check, Coq complains is not a constructor, while
it should:
Error: The symbol Example1 should be a constructor
Well... It is a constructor of the type I'm currently defining.
So is there a way around this?
Thank you for your help,
Lionel
pgpsF1gBOQr0I.pgp
Description: PGP signature
- [Coq-Club] Pattern matching while defining a type, Lionel Elie Mamane
- Message not available
- Re: [Coq-Club] Pattern matching while defining a type,
Lionel Elie Mamane
Frederic Blanqui
Lionel Elie Mamane
C T McBride
- Re: [Coq-Club] Pattern matching while defining a type, Lionel Elie Mamane
C T McBride
Lionel Elie Mamane
Eduardo Gimenez
Frederic Blanqui
Lionel Elie Mamane
- Re: [Coq-Club] Pattern matching while defining a type, Venanzio Capretta
