- To: Lionel Elie Mamane <lionel AT mamane.lu>
- Cc: Frederic Blanqui <blanqui AT lix.polytechnique.fr>, Venanzio Capretta <Venanzio.Capretta AT sophia.inria.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Pattern matching while defining a type
- Date: Wed, 23 Oct 2002 16:52:28 +0100 (BST)
Hello all
Subject to `size of type' restrictions, it is possible to turn
inductive-recursive definitions into inductive families. That is,
an inductive-recursive type with a decoder
T : Type
d : T -> D
becomes a family indexed by its decoding
F : D -> Type
Let's have an example. Apologies in advance for making the syntax up as I
go along...
For a suitable X, with distinctness predicate #,
DList : Type
fresh : DList -> X -> Prop
dnil : DList
dcons : (x:X)(xs:DList)(p:fresh xs x)DList
fresh dnil y = True
fresh (dcons x xs p) y = ((x # y) /\ (fresh xs y)
becomes
DList : (X -> Prop) -> Type
dnil : DList ([y:X]True)
dcons : (x:X)(fresh_xs:X->Prop)(xs:DList fresh_xs)(p:fresh_xs x)
(DList ([y:X](x # y) /\ (fresh_xs x)))
More generally, for each constructor c,
(1) replace recursive arguments (t:T) by
decoding-argument pairs (d_t:D)(t:F d)
i.e. make the constructor polymorphic in the decoding of its
recursive arguments
(2) correspondingly, replace applications of the decoder (d t) by the new
`decoding argument' d_t
(3) construct the index of the return type from the c-case of the decoder
i.e. replace the return type by (F d_c),
where d_c is [d_t / (d t)]rhs
where the original decoding function has
d (c ...) = rhs
You can now take
T = Sigma d : D. (F d)
and decode by first projection.
Now, if I remember rightly, the usual rules for inductive families
suggest that F must occupy at least as big a universe as D, which may
interfere with some uses of induction-recursion for universe
constructions. Also, if you have higher-order recursive arguments, then
their `decoding arguments' must also be lambda-lifted, which may cause
annoying technical difficulties in systems without eta-laws for function
spaces. But for simple examples like DList it works ok.
I don't pretend that this is pretty, but if you haven't got
induction-recursion, then it may be worth considering this fake.
Hope this helps
Conor
- [Coq-Club] Pattern matching while defining a type, Lionel Elie Mamane
- Message not available
- Re: [Coq-Club] Pattern matching while defining a type,
Lionel Elie Mamane
Frederic Blanqui
Lionel Elie Mamane
- Re: [Coq-Club] Pattern matching while defining a type, C T McBride
- Re: [Coq-Club] Pattern matching while defining a type, Lionel Elie Mamane
Lionel Elie Mamane
Eduardo Gimenez
Frederic Blanqui
Lionel Elie Mamane
- Re: [Coq-Club] Pattern matching while defining a type, Venanzio Capretta
