coq-club - Re: [Coq-Club] Pattern matching while defining a type
chronological Thread
  • To: Eduardo Gimenez <Eduardo.Gimenez AT trusted-logic.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Pattern matching while defining a type
  • Date: Tue, 22 Oct 2002 16:18:34 +0200
On Tue, Oct 22, 2002 at 03:51:28PM +0200, Eduardo Gimenez wrote:
> No, you can not do case analysis on the type you are introducing in the
> definition of the type itself (I can hardly imagine what the semantics of
> such construction could be :-).
Well, let's look at my example:
Inductive Example : Type :=
   Example1: nat -> Example
 | Example2:
  let check = [e:Example]
    Cases e of
     (Example1 n) => (lt (S (S O)) n)
    |(Example2 e p) => false
    end
  in
 (e:Example) (check e)-> Example.
This means that the constructor "Example2" awaits:
 0) an Example
 1) A proof that this Example satisfies predicate "check".
In other words, an Example is either:
 0) An Example1 of a natural number
 1) An Example2 of an (Example1 n), with n being at least 2.
The predicate "check", intuitively and "humanly" is well-defined,
isn't it? And isn't this semantic "reasonable"?
> Neither you can do a universal quantification on the type Example in
> the argument of a constructor of the type example.
This I most certainly can. This is accepted by Coq:
 | Example2: (e:Example) Example.
It is the same as
 | Example2: Example -> Example.
except in the former the user chooses a name for the argument of
constructor Example2. It is the same thing happening as in the
ultra-classic example of natural numbers:
Inductive nat : Set :=
   O: nat
  |S: (p:nat) nat.
 which is usually written:
    O: nat
   |S: nat -> nat.
May I remind you that (AFAIK), "P -> Q" is a syntactic shortcut for
"(x:P) Q", with x a "fresh" variable not occurring in Q?
> By the way, what is the intended meaning of the definition of the type
> Example?
It was the simplest I could think of that called for the construct I
wanted, for a more intricate type (that has only one constructor).
You may think of "Example1" Example's as generic Example's. An
(Example1 n) is called "pure" (or clean or ...) if its n is at least
2. An (Example2 e p) is then a "proved pure Example's".
Thank you for your time anyway,
Lionel
Attachment: pgpEp7kvVrr21.pgp
Description: PGP signature
