- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] How to prove two constructors are different
- Date: Fri, 19 Sep 2003 15:28:59 EDT
Hello, Given an inductive definition: Inductive A : Set := a : A | b : A | c : A. I want to prove that each pair of two constructors are different. Here is a proof following the method proposed in the book CoqArt: Lemma ineq : ~a=b. Proof. Unfold not; Intros H; Change ([o:A]Cases o of a => True | _ => False end b);Rewrite <- H; Trivial. Qed. Question: Are there simpler or general proofs for this problem ? With the above method, each lemma ~x=y needs a slightly different proof. Thanks. gang chen |
- [Coq-Club] How to prove two constructors are different, GANGCHEN5
- Re: [Coq-Club] How to prove two constructors are different, Pierre Casteran
- Re: [Coq-Club] How to prove two constructors are different, Jean-Yves Vion-Dury
