- From: Jean-Yves Vion-Dury <jean-yves.vion-dury AT inrialpes.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] How to prove two constructors are different
- Date: Mon, 22 Sep 2003 09:29:18 +0200
- Organization: Inria Rhones-Alpes
Goal ~(a=b) /\ ~(a=c) /\ ~(b=c).
> Repeat Split;Discriminate
GANGCHEN5 AT aol.com wrote:
Hello,
Given an inductive definition:
Inductive A : Set := a : A | b : A | c : A.
I want to prove that each pair of two constructors are
different. Here is a proof following the method proposed in the book CoqArt:
Lemma ineq : ~a=b.
Proof.
Unfold not; Intros H; Change ([o:A]Cases o of a => True | _ => False end b);Rewrite <- H; Trivial.
Qed.
Question:
Are there simpler or general proofs for this problem ?
With the above method, each lemma ~x=y needs a slightly different proof.
Thanks.
gang chen
Jean-Yves Vion-Dury Research Scientist | Xerox Research Centre Europe |
INRIA (sabbatical) 655 avenue de l'Europe, 38334 Montbonnot (FRANCE) Jean-Yves.Vion-Dury AT inrialpes.fr |
from France: 0 4 76 61 53 83 from abroad: +33 4 76 61 53 83 |
you may have a look at the Circus Transformation Language? | www.alphaAve.com |
- [Coq-Club] How to prove two constructors are different, GANGCHEN5
- Re: [Coq-Club] How to prove two constructors are different, Pierre Casteran
- Re: [Coq-Club] How to prove two constructors are different, Jean-Yves Vion-Dury
