- To: GANGCHEN5 AT aol.com
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] How to prove two constructors are different
- Date: Sat, 20 Sep 2003 08:44:29 +0200
- Organization: LaBRI
wrote:
Hello,
Given an inductive definition:
Inductive A : Set := a : A | b : A | c : A.
I want to prove that each pair of two constructors are
different. Here is a proof following the method proposed in the book CoqArt:
Lemma ineq : ~a=b.
Proof.
Unfold not; Intros H; Change ([o:A]Cases o of a => True | _ => False end b);Rewrite <- H; Trivial.
Qed.
Question:
Are there simpler or general proofs for this problem ?
With the above method, each lemma ~x=y needs a slightly different proof.
Thanks.
gang chen
It's better to use the "discriminate" tactic.
Lemma ineq : a <> b.
Proof.
Unfold not ; Discriminate 1.
Qed.
Then all lemmas have the same proof.
Pierre
Pierre Casteran,
LaBRI, Universite Bordeaux-I |
351 Cours de la Liberation |
F-33405 TALENCE Cedex |
France |
tel : (+ 33) 5 40 00 69 31
fax : (+ 33) 5 40 00 66 69
email: Pierre . Casteran @ labri . fr (but whithout white space)
www: http://www.labri.fr/Perso/~casteran
- [Coq-Club] How to prove two constructors are different, GANGCHEN5
- Re: [Coq-Club] How to prove two constructors are different, Pierre Casteran
- Re: [Coq-Club] How to prove two constructors are different, Jean-Yves Vion-Dury
