- To: coq-club AT pauillac.inria.fr
- Cc: Pierre Courtieu <pierre.courtieu AT univ-orleans.fr>, trc AT iis.sinica.edu.tw
- Subject: Re: [Coq-Club] values for type nat+nat+nat
- Date: Wed, 01 Oct 2003 17:10:23 +0800
Thanks! But the problem is that nat+nat+nat is not the same as nat+(nat+nat)
in Coq. As an evidence, try the following in the Coq toplevel:
Definition k: nat+nat+nat := (inr nat (nat+nat) (inr nat nat O)).
One gets the following error message in return:
Error: The term (inr nat nat+nat (inr nat nat O)) has type
nat+(nat+nat) while it is expected to have type nat+nat+nat
So, how does one express a value of type nat+nat+nat (which is builtin in Coq)?
best,
Tyng-Ruey
Pierre Courtieu wrote:
Hello,
Values of type nat+nat are for example:
(inl nat nat O)
(inr nat nat O)
Values of type nat + (nat+nat) are for example:
(inl nat (nat+nat) O).
(inr nat (nat+nat) (inl nat nat O))
Cheers,
Pierre
Tyng-Ruey Chuang
<trc AT iis.sinica.edu.tw>
wrote:
Hi,
Here comes a question from a novice:
What is the syntax for creating and destructing values
of type nat+nat+nat ?
For nat+nat, there are inl and inr predefined in the Standard Library.
(I assume nat+nat is the shorthand for (sum nat nat))
It seems to be that Coq toplevel understands type nat+nat+nat,
which is different from nat+(nat+nat), but I cannot find Coq syntax
to construct and desctruct values of this types.
Sorry if this a FAQ. Thanks in advance.
best,
Tyng-Ruey Chuang
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] values for type nat+nat+nat, Tyng-Ruey Chuang
- Re: [Coq-Club] values for type nat+nat+nat,
Pierre Courtieu
- Re: [Coq-Club] values for type nat+nat+nat, Tyng-Ruey Chuang
Pierre Letouzey
Pierre Courtieu
