- From: Pierre Courtieu <pierre.courtieu AT univ-orleans.fr>
- Cc: coq-club AT pauillac.inria.fr, trc AT iis.sinica.edu.tw
- Subject: Re: [Coq-Club] values for type nat+nat+nat
- Date: Wed, 1 Oct 2003 10:56:01 +0200
Hello,
Values of type nat+nat are for example:
(inl nat nat O)
(inr nat nat O)
Values of type nat + (nat+nat) are for example:
(inl nat (nat+nat) O).
(inr nat (nat+nat) (inl nat nat O))
(inr nat (nat+nat) (inr nat nat O))
Cheers,
Pierre
Tyng-Ruey Chuang
<trc AT iis.sinica.edu.tw>
wrote:
> Hi,
> Here comes a question from a novice:
> What is the syntax for creating and destructing values
> of type nat+nat+nat ?
> For nat+nat, there are inl and inr predefined in the Standard Library.
> (I assume nat+nat is the shorthand for (sum nat nat))
> It seems to be that Coq toplevel understands type nat+nat+nat,
> which is different from nat+(nat+nat), but I cannot find Coq syntax
> to construct and desctruct values of this types.
> Sorry if this a FAQ. Thanks in advance.
> best,
> Tyng-Ruey Chuang
> Bug reports: http://coq.inria.fr/bin/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] values for type nat+nat+nat, Tyng-Ruey Chuang
- Re: [Coq-Club] values for type nat+nat+nat, Pierre Courtieu
- Re: [Coq-Club] values for type nat+nat+nat, Tyng-Ruey Chuang
Pierre Letouzey
