- To: coq-club AT pauillac.inria.fr
- Cc: Pierre Letouzey <Pierre.Letouzey AT lri.fr>, trc AT iis.sinica.edu.tw
- Subject: Re: [Coq-Club] values for type nat+nat+nat
- Date: Wed, 01 Oct 2003 17:16:00 +0800
Ah, left associativity! Many thanks!
Tyng-Ruey
Pierre Letouzey wrote:
On Wed, 1 Oct 2003, Tyng-Ruey Chuang wrote:
It seems to be that Coq toplevel understands type nat+nat+nat,
which is different from nat+(nat+nat), but I cannot find Coq syntax
to construct and desctruct values of this types.
nat+nat+nat is (nat+nat)+nat because of implicit left parenthesis.
It is indeed different from nat+(nat+nat).
You can then build a value in this type by using two levels of inl and inr:
(* left handside: *)
Coq < Check (inl nat+nat nat (inl nat nat O)).
(inl nat+nat nat (inl nat nat (0)))
: nat+nat+nat
(* middle: *)
Coq < Check (inl nat+nat nat (inr nat nat O)).
(inl nat+nat nat (inr nat nat (0)))
: nat+nat+nat
(* right handside *)
Coq < Check (inr nat+nat nat O).
(inl nat+nat nat (0))
: nat+nat+nat
This ... + ... + ... syntax is similar to what is used in theorem
lt_eq_lt_dec (file Compare_dec.v):
Coq < Require Compare_dec.
Coq < Check lt_eq_lt_dec.
lt_eq_lt_dec
: (n,m:nat){(lt n m)}+{n=m}+{(lt m n)}
Finally, if you really want a ternary "or" without this "two level"
encoding, you can do that via an new inductive definition:
Inductive ternary_or [A,B,C:Set] : Set :=
the_left : A -> (ternary_or A B C)
| the_middle : B -> (ternary_or A B C)
| the_right : C -> (ternary_or A B C).
Pierre Letouzey
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] values for type nat+nat+nat, Tyng-Ruey Chuang
- Re: [Coq-Club] values for type nat+nat+nat,
Pierre Courtieu
- Re: [Coq-Club] values for type nat+nat+nat, Tyng-Ruey Chuang
Pierre Letouzey
Pierre Courtieu
