- To: Jacek Chrzaszcz <chrzaszc AT mimuw.edu.pl>
- Cc: Houda Anoun <anoun AT labri.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] problem with notations
- Date: Tue, 13 Jan 2004 14:00:16 +0100
- Organization: LaBRI
Jacek Chrzaszcz wrote:
On Mon, Jan 12, 2004 at 01:03:15PM +0100, Houda Anoun wrote:
Seriously, in situations like this one:
Module M:T:=A
one has to decide which elements come from T and which from A.
Now they simply all come from T.
There is a slight problem. This work only if we work with opaque
signature constraint , and not if I use '<:'
Module Type S1.
Inductive P : Set :=
c : P.
Notation "'XXX'" := c (at level 40) : my_scope.
End S1.
Module M1 <: S1.
c : P .
End M1.
Import M1.
(* Open Scope my_scope.
Error: Scope my_scope is not declared *)
If I use a constraint with ':', the notation is available :
Module M2 : S1.
c : P .
End M2.
Import M2.
Check c.
XXX : P
By the way, I have often to deal with inductive type definitions.
Is it OK to put the inductive definition in the signature (since
it is a declaration of the constructors and the _ind, _rec, ...
theorems), and duplicate the inductive definition in the signature
and in the module and/or functor ?.
Pierre
P.S.
Jacek, Igor (Walukiewicz) told me about your thesis. Congratulations !
Pierre Casteran,
LaBRI, Universite Bordeaux-I |
351 Cours de la Liberation |
F-33405 TALENCE Cedex |
France |
tel : (+ 33) 5 40 00 69 31
fax : (+ 33) 5 40 00 66 69
email: Pierre . Casteran @ labri . fr (but whithout white space)
www: http://www.labri.fr/Perso/~casteran
- [Coq-Club] problem with notations, Houda Anoun
- Re: [Coq-Club] problem with notations,
Jacek Chrzaszcz
- Re: [Coq-Club] problem with notations, Pierre Casteran
- Re: [Coq-Club] problem with notations, Jacek Chrzaszcz
Houda Anoun
- <Possible follow-ups>
Jevgenijs Sallinens
- Re: [Coq-Club] problem with notations, Pierre Courtieu
- Re: [Coq-Club] problem with notations, Houda Anoun
Jevgenijs Sallinens
- Re: [Coq-Club] problem with notations, Jevgenijs Sallinens
Jacek Chrzaszcz
