- To: Jacek Chrzaszcz <chrzaszc AT mimuw.edu.pl>, coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] problem with notations
- Date: Mon, 19 Jan 2004 11:03:22 +0100
Hi ,
Here is another problem with notations:
Module Type SIGNot.
Inductive InfTwoNat:nat-> Prop:=
ohConstructorTooLong: forall (n:nat), InfTwoNat n.
Notation "<<< n " :=(ohConstructorTooLong n ) (at level 40):new_scope.
End SIGNot.
Module sigImpl <:SIGNot.
Inductive InfTwoNat:nat ->Prop:=
End sigImpl.
Module Type FUN.
Declare Module sigsig :SIGNot.
End FUN.
Module Ext (picsou:SIGNot)<:FUN.
Module sigsig:=picsou.
End Ext.
Module foufou(fun1:FUN)(fun2:FUN with Module sigsig:=fun1.sigsig).
Open Scope new_scope.
Import fun1.sigsig.
Check (fun1.sigsig.ohConstructorTooLong O).
(* Coq < <<< 0
: InfTwoNat 0 the notation works :-) *)
Check (fun2.sigsig.ohConstructorTooLong O).
(* fun2.sigsig.ohConstructorTooLong 0
: fun2.sigsig.InfTwoNat 0 it doesn't work :-( *)
As we see both fun1.sigsig and fun2.sigsig are of type SIGNot where the
notation is defined...
I think this problem results from the equivalence between modules which is
not supported by the current version of Coq...in fact we have
fun1.sigsig=fun2.sigsig ...
Can this problem be solved ?!
Pierre Casteran wrote:
Jacek Chrzaszcz wrote:
On Mon, Jan 12, 2004 at 01:03:15PM +0100, Houda Anoun wrote:
Seriously, in situations like this one:
Module M:T:=A
one has to decide which elements come from T and which from A.
Now they simply all come from T.
There is a slight problem. This work only if we work with opaque
signature constraint , and not if I use '<:'
Module Type S1.
Inductive P : Set :=
c : P.
Notation "'XXX'" := c (at level 40) : my_scope.
End S1.
Module M1 <: S1.
c : P .
End M1.
Import M1.
(* Open Scope my_scope.
Error: Scope my_scope is not declared *)
If I use a constraint with ':', the notation is available :
Module M2 : S1.
c : P .
End M2.
Import M2.
Check c.
XXX : P
By the way, I have often to deal with inductive type definitions.
Is it OK to put the inductive definition in the signature (since
it is a declaration of the constructors and the _ind, _rec, ...
theorems), and duplicate the inductive definition in the signature
and in the module and/or functor ?.
Pierre
P.S.
Jacek, Igor (Walukiewicz) told me about your thesis. Congratulations !
- [Coq-Club] problem with notations, Houda Anoun
- Re: [Coq-Club] problem with notations,
Jacek Chrzaszcz
Pierre Casteran
- Re: [Coq-Club] problem with notations, Jacek Chrzaszcz
- Re: [Coq-Club] problem with notations, Houda Anoun
Pierre Casteran
- <Possible follow-ups>
Jevgenijs Sallinens
- Re: [Coq-Club] problem with notations, Pierre Courtieu
Jevgenijs Sallinens
- Re: [Coq-Club] problem with notations, Pierre Casteran
- Re: [Coq-Club] problem with notations, Jevgenijs Sallinens
Jacek Chrzaszcz
