- From: Pierre Courtieu <Pierre.Courtieu AT univ-orleans.fr>
- To: "Jevgenijs Sallinens" <jevgenijs AT dva.lv>
- Cc: "Jacek Chrzaszcz" <chrzaszc AT mimuw.edu.pl>, "Pierre Casteran" <casteran AT labri.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] problem with notations
- Date: Thu, 15 Jan 2004 16:02:48 +0100
On Thu, 15 Jan 2004 16:15:06 +0200
wrote:
> Lemma Nat_1x : (n,m: Nat) ((eq_Nat n m) = true)->(eq Nat n m).
If you put NA2.NA.eq_Nat instead of eq_Nat in the type of the lemme, then
the script works works... Don't understand why this is necessary.
Pierre
- [Coq-Club] problem with notations, Houda Anoun
- Re: [Coq-Club] problem with notations,
Jacek Chrzaszcz
Pierre Casteran
- Re: [Coq-Club] problem with notations, Jacek Chrzaszcz
Houda Anoun
Pierre Casteran
- <Possible follow-ups>
Jevgenijs Sallinens
- Re: [Coq-Club] problem with notations, Pierre Courtieu
- Re: [Coq-Club] problem with notations, Houda Anoun
Jevgenijs Sallinens
- Re: [Coq-Club] problem with notations, Pierre Casteran
- Re: [Coq-Club] problem with notations, Jevgenijs Sallinens
Jacek Chrzaszcz
