coq-club - Re: [Coq-Club] Re: Inductives in Modules
chronological Thread
  • From: Roland Zumkeller <Roland.Zumkeller AT polytechnique.fr>
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Re: Inductives in Modules
  • Date: Mon, 24 May 2004 18:05:10 +0200
Here is the response of Jacek Chrzaszcz (it didn't go to the list).
Le 13 mai 04, à 17:10, Jacek Chrzaszcz a écrit :
This is a known deficiency od the implementation of modules in
Coq. This is purely a technical problem, but a painful one.
We hope to solve this problem in the future... but it requires heavy
modifications in many places of the Coq sources....
Jacek
Le 24 mai 04, à 17:37, Frederic Blanqui a écrit :
i encountered the same problem too. i think that inductives are not seen as
other definitions. could this be changed in a future version of coq?
--------------- previous message ------------------
Roland Zumkeller
Thu, 13 May 2004 16:27:09 +0200
I'd like to use modules to do model first-order signatures and algebras
on them :
Module Type Signature.
   Variable V : Set.
   Variable F : nat -> Set.
End Signature.
When defining the following module
Module S : Signature.
   Inductive V : Set:= X | Y.
   Inductive F : nat -> Set:= Plus : F 2 | Zero : F 0 | One : F 0.
End S.
I get this error message:
   "User error: Signature components for label V do not match"
However when defining the inductive with another name first, everything
works fine.
Module S1 : Signature.
   Inductive V_ : Set:= X | Y.
   Definition V := V_.
   Inductive F_ : nat -> Set:= Plus : F_ 2 | Zero : F_ 0 | One : F_ 0.
   Definition F := F_.
End S1.
Is this a bug or is there a deeper reason for this ?
