- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Problems with reduction ?
- Date: Fri, 18 Jun 2004 10:10:22 +0200
- Organization: LaBRI
Hello,
I have some problems with type equivalence.
Let us consider the following declarations:
Set Implicit Arguments.
Record Signature : Type := {
V : Set; (* variables *)
C : Set; (* constants *)
P : nat -> Set (* predicates with arity *)
Section form_def.
Variable sigma : Signature.
Inductive dForm : Set :=
| dall : V sigma -> dForm -> dForm
| dtrue : dForm.
End form_def.
Ok, I want to build some signature for an example:
Inductive vars: Set := x | y.
Inductive consts : Set :=.
Inductive preds : nat -> Set :=
| donkey : preds 1
| farmer : preds 1.
Definition sigma : Signature.
split.
exact vars.
exact consts.
exact preds.
Defined.
But I cannot build simply a formula :
Implicit Arguments dtrue [sigma].
Definition f : dForm sigma :=
dall x dtrue.
Toplevel input, characters 99-100
> Definition f : dForm sigma := dall x dtrue.
Error: The term "x" has type "vars" while it is expected to have type "V ?5"
Nevertheless, putting explicit type constraint on x will work, but I don't know why I should be so explicit, cause, by constraining the type of f
I gave enough information, no?
Definition f0 : dForm sigma :=
dall (x:V sigma) dtrue.
f0 is defined.
Is there some way to avoid explicit type constraints like (x: V sigma) ?
Pierre
Pierre Casteran,
LaBRI, Universite Bordeaux-I |
351 Cours de la Liberation |
F-33405 TALENCE Cedex |
France |
tel : (+ 33) 5 40 00 69 31
fax : (+ 33) 5 40 00 66 69
email: Pierre . Casteran @ labri . fr (but whithout white space)
www: http://www.labri.fr/Perso/~casteran
- [Coq-Club] Problems with reduction ?, Pierre Casteran
- Re: [Coq-Club] Problems with reduction ?, Pierre Casteran
Conor T McBride
- Re: [Coq-Club] Problems with reduction ?, Bruno Barras
- <Possible follow-ups>
SAIBI Amokrane
