coq-club - Re: [Coq-Club] Problems with reduction ?
chronological Thread
  • To: Conor T McBride <c.t.mcbride AT durham.ac.uk>
  • Cc: Pierre Casteran <casteran AT labri.fr>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Problems with reduction ?
  • Date: Tue, 22 Jun 2004 17:02:18 +0200
Conor T McBride a écrit :
Now, this I find a little odd. Why does this work when the other does
not? Now the first constraint reads
  V sigma = V ?a
from which one cannot conclude that necessarily ?a = sigma, just that ?a
must have a V projection coinciding with sigma's. Is this what's
happening? Of course, ?a = sigma is a very plausible guess under the
circumstances, even if it is not necessarily the case, so perhaps it's
good in practice to make that choice. I'm pretty sure that Lego would
take ?a = sigma here, although I'm not sure that I'd want it to.
At least that's what the implementor of the record layer wanted. Equations involving projections have this behaviour (unify the projected records, and in case of failure unify the projections themselves), altough I'm not sure the implementation is very uniform in this choice. This could explain that unification does not go through.
This was jusitified by Amokrane Saibi's ALGEBRA contribution, where algebraic structure are seen as records and the carrier set is one field of that record. Typically you have a record (say R_ring) stating that real numbers make up a ring and its carrier set is R (the set of real numbers). Then you often are in a situation where you have to guess a ring structure knowing only that its carrier is the same as that of R_ring. In this case you are happy that Coq infers that this is R_ring (you generally consider only one ring with carrier R).
In other cases that's far from obvious. For instance think of rational numbers, if you have to guess a rational with the same denominator as 1/2, it's not clear it's 1/2...
My feeling is that Coq's behaviour is sensible only in the case of records with only one "important" field. Or at least such equations should be postponed.
Cheers,
Bruno Barras.
