coq-club - Re: [Coq-Club] Problems with reduction ?
chronological Thread
  • To: Pierre Casteran <casteran AT labri.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Problems with reduction ?
  • Date: Fri, 18 Jun 2004 11:11:19 +0200
  • Organization: LaBRI
I've just tried some solution, but it seems rather heavy.
Inductive vars : Set := _x | _y.
Inductive preds : nat -> Set :=
    | _donkey : preds 1
    | _farmer : preds 1.
Inductive consts : Set := .
 Definition sigma : Signature.
 split.
 exact vars.
 exact consts.
 exact preds.
Defined.
Definition x : V sigma := _x.
Definition y : V sigma := _y.
Definition donkey : P sigma 1 := _donkey.
etc.
With this trick,
the formula definition like
Definition f : dForm sigma :=
    dall x dtrue.
is accepted.
Pierre
Pierre Casteran wrote:
Hello,
  I have some problems with type equivalence.
   Let us consider the following declarations:
Set Implicit Arguments.
Record Signature : Type := {
  V : Set; (* variables *)
  C : Set; (* constants *)
  P : nat -> Set (* predicates with arity *)
Section form_def.
Variable sigma : Signature.
Inductive dForm : Set :=
  |   dall : V sigma -> dForm -> dForm
  |   dtrue : dForm.
End form_def.
Ok, I want to build some signature for an example:
Inductive vars: Set := x | y.
Inductive consts : Set :=.
  | donkey : preds 1
  | farmer : preds 1.
 split.
 exact vars.
 exact consts.
 exact preds.
Defined.
But I cannot build simply a formula :
Implicit Arguments dtrue [sigma].
    dall x dtrue.
Toplevel input, characters 99-100
 > Definition f : dForm sigma :=     dall x dtrue.
Error: The term "x" has type "vars" while it is expected to have type "V ?5"
Nevertheless, putting explicit type constraint on x will work, but I don't know why I should be so explicit, cause, by constraining the type of f
I gave enough information, no?
Definition f0 : dForm sigma :=
   dall (x:V sigma) dtrue.
f0 is defined.
Is there some way to avoid explicit type constraints like (x: V sigma) ?
Pierre
Pierre Casteran,
LaBRI, Universite Bordeaux-I      |
351 Cours de la Liberation        |
F-33405 TALENCE Cedex             |
France                            |
tel : (+ 33) 5 40 00 69 31
fax : (+ 33) 5 40 00 66 69
email: Pierre . Casteran @ labri .  fr  (but whithout white space)
www: http://www.labri.fr/Perso/~casteran
