- To: Wojciech Moczydlowski <wm174746 AT zodiac.mimuw.edu.pl>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] nat : Type?
- Date: Mon, 21 Jun 2004 08:40:12 +0200
- Organization: LaBRI
Wojciech Moczydlowski wrote:
Hello,
I'm a Ph. D. student in computer science and a newbie to Coq. During my sessions with it I encountered the following behavior:
If I declare
Variable x : Type -> Type
in Coq 8.0
then (x nat) typechecks, that is Check (x nat) says that (x nat) : Type. This seems weird, for I do not see how to derive nat : Type from the inference rules in the documentation on the webpage, which seem to be necessary to derive (x nat) : Type. What am I missing?
Thanks.
You can derive nat:Type thanks to the convertibility order and the conversion rule :
I I denote by <= the convertibility order, you have Set <= Type(i) for
any i.
The conversion rule allows you to derive
nat : Set Set <= Type(0)
nat : Type(0)
For instance, take the equality predicate :
eq : forall A : Type, A -> A -> Prop
Since you have also nat : Type,
you can consider equality between two natural numbers, like
eq nat 2 3.
Pierre
P.S.
This example is treated pages 39 and 90 of the book by Bertot et al.
Wojtek
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Pierre Casteran,
LaBRI, Universite Bordeaux-I |
351 Cours de la Liberation |
F-33405 TALENCE Cedex |
France |
tel : (+ 33) 5 40 00 69 31
fax : (+ 33) 5 40 00 66 69
email: Pierre . Casteran @ labri . fr (but whithout white space)
www: http://www.labri.fr/Perso/~casteran
- [Coq-Club] nat : Type?, Wojciech Moczydlowski
- Re: [Coq-Club] nat : Type?, Pierre Casteran
- [Coq-Club] convertibility,
Jean-Yves Vion-Dury
- Re: [Coq-Club] convertibility, Houda Anoun
- [Coq-Club] Impredicativity in Coq, Wojciech Moczydlowski
Jean-Yves Vion-Dury
