- To: Jean-Yves Vion-Dury <jean-yves.vion-dury AT inrialpes.fr>
- Cc: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] convertibility
- Date: Tue, 22 Jun 2004 11:11:29 +0200
Hi,
The term "rx+ry=ry+rx" is not the beta contraction of (Rplus_comm rx ry) but its type....
In other terms (Rplus_comm rx ry) is a proof of (rx+ry=ry+rx)....
The term (Rplus_comm rx ry) -> True is not well formed (because (Rplus_comm rx ry) 's type is not a sort ...,
that is the case for example for nat -> nat which is well formed and 0 -> nat which is not... 0:nat !!)
Hope this helps
Houda
Dear colleagues
I cannot understand for instance why
Require Import Reals.
Check forall rx ry:R, (Rplus_comm rx ry) -> True.
produces the error :
Error: In environment
rx : R
ry : R
the term "Rplus_comm rx ry" has type "rx + ry = ry + rx"
which should be Set, Prop or Type.
whereas
Check forall rx ry:R, rx+ry = ry+rx -> True.
produces
forall rx ry : R, rx + ry = ry + rx -> True
: Prop
but, to me, rx+ry=ry+rx is the beta-contraction of (Rplus_comm rx ry)
and hence, the type should be convertible.
any comment much appreciated.
Jean-Yves
Jean-Yves Vion-Dury <http://wam.inrialpes.fr/people/index.en.html> /Research Scientist/ * Xerox Research Centre Europe *
*INRIA* (sabbatical)
655 avenue de l'Europe,
38334 Montbonnot (FRANCE)
Jean-Yves.Vion-Dury AT inrialpes.fr <mailto:Jean-Yves.Vion-Dury AT inrialpes.fr> from France: 0 4 76 61 53 83
from abroad: +33 4 76 61 53 83
you may have heard of *Circus*the Transformation Language I designed ? show me <http://www.google.com/search?q=Circus-DTE&ie=UTF-8&oe=%0A=UTF-8>
- [Coq-Club] nat : Type?, Wojciech Moczydlowski
- Re: [Coq-Club] nat : Type?,
Pierre Casteran
- [Coq-Club] convertibility,
Jean-Yves Vion-Dury
- Re: [Coq-Club] convertibility, Houda Anoun
- [Coq-Club] Impredicativity in Coq, Wojciech Moczydlowski
Jean-Yves Vion-Dury
Pierre Casteran
