- To: Pierre Courtieu <Pierre.Courtieu AT univ-orleans.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] java & coq
- Date: Wed, 23 Jun 2004 18:04:49 +0200
It's a toolkit for computational linguitics based on multimodal grammars
(extension of Lambek grammars)...
Houda
Selon Pierre Courtieu
<Pierre.Courtieu AT univ-orleans.fr>:
> On 23 jun 2004, Sébastien Hinderer wrote:
> > Hello,
> > One solution I see is to have two processes: one for your interface, the
> > other for Coq.
> > The idea is that the coq process is executed by your interface (with th
> fork
> > and exec system calls).
> > The communication is then done using two pipes. One allows the interface
> > to
> > send datas to Coq on his standard input, the other one is used to fetch
> > messages sent by Coq on his standard output.
> > I guess this is the technique use by Emacs and proof-general...
> This is also the technique used in Pcoq (which is written in Java by the
> way). Can you precise what kind of tool you are realising?
> Pierre Courtieu
This message was sent using IMP, the Internet Messaging Program.
- [Coq-Club] java & coq, Houda Anoun
- Re: [Coq-Club] java & coq,
Sébastien Hinderer
Pierre Courtieu
- Re: [Coq-Club] java & coq, anoun
Pierre Courtieu
- Re: [Coq-Club] java & coq, David Aspinall
- <Possible follow-ups>
- RE: [Coq-Club] java & coq, James Smith
- Re: [Coq-Club] java & coq, James Smith
Sébastien Hinderer
