- To: <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] java & coq
- Date: Thu, 24 Jun 2004 11:19:02 +0100
Houda, hi, if your aim is to provide an
application for non-specialist users then you should ask what your interface
provides. If you simply intend to echo the output of Coq I doubt that a Java
interface (or any other, for that matter) would provide anything over and
above, say, Emacs. A better solution may be to
look at Epigram - I know Conor is keen to work on developing an enhanced
interface to Epigram that can be used with graphical interfaces and Epigram's
two dimensional syntax my well be more suited non-specialist users. Regards, Jim |
- [Coq-Club] java & coq, Houda Anoun
- Re: [Coq-Club] java & coq,
Sébastien Hinderer
Pierre Courtieu
- Re: [Coq-Club] java & coq, anoun
Pierre Courtieu
- Re: [Coq-Club] java & coq, David Aspinall
- <Possible follow-ups>
- RE: [Coq-Club] java & coq, James Smith
- Re: [Coq-Club] java & coq, James Smith
Sébastien Hinderer
