- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] extracting sub-proofs
- Date: Tue, 06 Jul 2004 12:13:59 +0200
Hi everybody;
I found problems while trying to extract sub proofs whose type is not known in a first time
Let's take a simple example :
Inductive fofo:nat ->nat-> Set:=
fo1:forall (n:nat), fofo n (n+2).
Inductive toto(n:nat):Set:=
to1: forall (m:nat), fofo m n -> toto n.
If we consider that pf is a proof of (toto n) for a natural number n, I want to extract from this proof a proof of (fofo m n) that has been used to prove (toto n).
The problem is that m is unknown and has to be calculated
The solution I found doesn't work, it's the following one:
Definition extractInt (n:nat)(pf:toto n):nat:=
match pf with
to1 m _ => m
end.
Definition getProof(n:nat)(pf:toto n):fofo (extractInt n pf) n:=
match pf with
| to1 _ pf1 => pf1
end.
But it seems that there is a problem of type conversion in this solution ...
Can anyone help me to solve this...
Thanks in advance
Houda
| Houda ANOUN |
| LaBRI |
| 351 Cours de la libération |
| 33405 Talence |
| phone: 0540002489 |
:anoun AT labri.fr
- [Coq-Club] extracting sub-proofs, Houda Anoun
- Re: [Coq-Club] extracting sub-proofs, Pierre Letouzey
- Re: [Coq-Club] extracting sub-proofs, Pierre Casteran
- Re: [Coq-Club] extracting sub-proofs, Benjamin Werner
