- To: Houda Anoun <anoun AT labri.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] extracting sub-proofs
- Date: Tue, 6 Jul 2004 13:12:17 +0200 (MEST)
On Tue, 6 Jul 2004, Houda Anoun wrote:
> Hi everybody;
> I found problems while trying to extract sub proofs whose type is not
> known in a first time
> Let's take a simple example :
> Inductive fofo:nat ->nat-> Set:=
> fo1:forall (n:nat), fofo n (n+2).
> Inductive toto(n:nat):Set:=
> to1: forall (m:nat), fofo m n -> toto n.
> If we consider that pf is a proof of (toto n) for a natural number n, I
> want to extract from this proof a proof of (fofo m n) that has been used
> to prove (toto n).
> The problem is that m is unknown and has to be calculated
> The solution I found doesn't work, it's the following one:
> Definition extractInt (n:nat)(pf:toto n):nat:=
> match pf with
> to1 m _ => m
> end.
> Definition getProof(n:nat)(pf:toto n):fofo (extractInt n pf) n:=
> match pf with
> | to1 _ pf1 => pf1
> end.
> But it seems that there is a problem of type conversion in this solution ...
> Can anyone help me to solve this...
You need to help the last "match" via the "return" construction:
match pf return fofo (extractInt n pf) n with
| to1 _ pf1 => pf1
end.
You can find more documentation about the variants of "match" in Coq
Reference Manual.
Pierre Letouzey
- [Coq-Club] extracting sub-proofs, Houda Anoun
- Re: [Coq-Club] extracting sub-proofs, Pierre Letouzey
- Re: [Coq-Club] extracting sub-proofs, Pierre Casteran
- Re: [Coq-Club] extracting sub-proofs, Benjamin Werner
