- To: anoun AT labri.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] extracting sub-proofs
- Date: Tue, 06 Jul 2004 13:12:41 +0200
- Organization: LaBRI
Bonjour Houda,
This problem can be solve as follows.
When some function body seems too hard to build, I try ato build it interactively, and look at the printed term.
Inductive fofo:nat ->nat-> Set:=
fo1:forall (n:nat), fofo n (n+2).
Inductive toto(n:nat):Set:=
to1: forall (m:nat), fofo m n -> toto n.
Definition extractInt (n:nat)(pf:toto n):nat:=
match pf with
to1 m _ => m
end.
Definition getProof(n:nat)(pf:toto n):fofo (extractInt n pf) n.
destruct pf.
simpl.
assumption.
Qed.
Print getProof.
getProof =
fun (n : nat) (pf : toto n) =>
match pf as t return (fofo (extractInt n t) n) with
| to1 m f => f
end
: forall (n : nat) (pf : toto n), fofo (extractInt n pf) n
Ok, the solution is in the match ... as .. return ...
construct.
In the book, Yves wrote some pages 'bout that in section "Dependent inductive types" (section 6.5).
Houda Anoun wrote:
Hi everybody;
I found problems while trying to extract sub proofs whose type is not known in a first time
Let's take a simple example :
If we consider that pf is a proof of (toto n) for a natural number n, I want to extract from this proof a proof of (fofo m n) that has been used to prove (toto n).
The problem is that m is unknown and has to be calculated
The solution I found doesn't work, it's the following one:
match pf with
to1 m _ => m
end.
Definition getProof(n:nat)(pf:toto n):fofo (extractInt n pf) n:=
match pf with
| to1 _ pf1 => pf1
end.
But it seems that there is a problem of type conversion in this solution ...
Can anyone help me to solve this...
Thanks in advance
Houda
Pierre Casteran,
LaBRI, Universite Bordeaux-I |
351 Cours de la Liberation |
F-33405 TALENCE Cedex |
France |
tel : (+ 33) 5 40 00 69 31
fax : (+ 33) 5 40 00 66 69
email: Pierre . Casteran @ labri . fr (but whithout white space)
www: http://www.labri.fr/Perso/~casteran
- [Coq-Club] extracting sub-proofs, Houda Anoun
- Re: [Coq-Club] extracting sub-proofs, Pierre Letouzey
- Re: [Coq-Club] extracting sub-proofs, Pierre Casteran
- Re: [Coq-Club] extracting sub-proofs, Benjamin Werner
