coq-club - Re: [Coq-Club] Evaluation and comparisons on the natural numbers
chronological Thread
  • From: Guillaume Dufay <Guillaume.Dufay AT sophia.inria.fr>
  • To: Brian Emre Aydemir <baydemir AT cis.upenn.edu>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Evaluation and comparisons on the natural numbers
  • Date: Fri, 24 Sep 2004 23:41:27 -0400
  • Organization: INRIA Sophia Antipolis
Brian Emre Aydemir a écrit :
Hi,
So if n and m have type nat, I'd like to be able to write something like
  if (n < m) then X else Y
and be able to reduce/simplify that down to either X or Y somehow. However, what I wrote doesn't work since (n < m) has type Prop. So instead, I could write (lt_ge_dec n m).
Then my question is: how do I simplify (if (lt_ge_dec n m) then X else Y) down to X or Y? For example, I'm guessing I need to do a case analysis on (n < m \/ n >= m), but how do I prove that assertion. And then once I'm assuming one of the cases, say (n < m), how do I proceed to simplify the expression? Perhaps lt_ge_dec is not the way to go, but then I haven't been able to find anything else that works. As a related question: are there any comparison functions on the natural numbers with the type (nat -> nat -> bool)? Or maybe I should try working with the integers instead?
Hello,
You can simply do a case analysis on (lt_ge_dec n m), which is an
inductive type. You will find below an example of such a use.
Hope this helps.
Regards.
Require Import Lt.
Require Import Bool_nat.
Definition foo (n m:nat) :=
match (lt_ge_dec n m) with
| (left _) => true
| (right _) => false
end.
Lemma bar : forall n m, n < m -> (foo n m) = true.
unfold foo.
intros.
case (lt_ge_dec n m).
reflexivity.
intro H0.
elim (lt_not_le n m H H0).
Qed.
Guillaume
