- To: Param Jyothi Reddy <paramr AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] symmety in leibniz equality
- Date: Thu, 13 Jan 2005 08:40:42 +0100
On Thu, Jan 13, 2005 at 10:55:01AM +0530, Param Jyothi Reddy wrote:
> Hi all, I was trying to understand how in intutionistic logic
> (forall P)(P(x)->P(y)) |- (forall P)(P(y)->P(x))
> is true.
> So i took a look at how Coq proves this.
> (http://www.labri.fr/Perso/~casteran/CoqArt/depprod/SRC/leibniz.v)
> leibniz_sym < intros a b H Q.
> 1 subgoal
> A : Set
> a : A
> b : A
> H : forall P : A -> Prop, P a -> P b
> Q : A -> Prop
> Q b -> Q a
> leibniz_sym < apply H.
> 1 subgoal
> A : Set
> a : A
> b : A
> Q : A -> Prop
> Q a -> Q a
> I am unable to understand how apply H resulted in Q a-> Q a. (My
> expectation was H applied to Q would be Q a -> Q b)
H is not applied to Q; "Apply" is being smarter than you (and I)
expect it to be. The P of H is not being unified with "Q", but with
something else. Indeed, if you try "Apply (H Q)." instead of just
"Apply.", you'll see that this doesn't work (it doesn't unify).
If you finish the proof and look at the lambda-term directly (with
"Print"), you'll see that the P of H is unified with
(fun c : A => Q c -> Q a)
thus (P b) is (Q b -> Q a), our whole goal, and the application
generates as subgoal (P a), i.e. (Q a -> Q a).
Lionel
- [Coq-Club] symmety in leibniz equality, Param Jyothi Reddy
- Re: [Coq-Club] symmety in leibniz equality, Remi Vanicat
- Re: [Coq-Club] symmety in leibniz equality, Lionel Elie Mamane
- Re: [Coq-Club] symmety in leibniz equality, Pierre Casteran
