coq-club - [Coq-Club] Type safety
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Cc: nogin AT cs.caltech.edu
  • Subject: [Coq-Club] Type safety
  • Date: Thu, 10 Feb 2005 22:32:32 -0800
  • Organization: Caltech
Hi everyone,
I have been looking at the type system in Coq, wondering what properties it ensures for proofs. Thinking as an adversary, I borrowed some code from the Coq kernel. Note, I didn't insert this into the kernel, I just load this code from coqtop.
    let internal_cut_rev_no_check id t gl =
      refiner (Prim (Cut (false, id, t))) gl
    let hack_tactic c gl =
let id = next_name_away_with_default "H" Anonymous (pf_ids_of_hyps gl) in
          internal_cut_rev_no_check id c gl;;
    TACTIC EXTEND Hack
    | ["Hack" constr(c) ] -> [hack_tactic c]
    END
Next we try a proof.
   Coq < Declare ML Module "hack".
   Coq < Variables A : Prop.
   Coq < Goal A.
   Unnamed_thm < hack O.
   2 subgoals
   H : 0
   A
   subgoal 2 is:
This seems suprising to me. Even though the second subgoal is unprovable, both subgoals are ill-formed. Is this expected? Is it accurate to say that proofs are valid only if one uses the "approved" functions from the kernel, and one does not use the refiner directly?
Perhaps the Coq semantics ensure that proofs using ill-typed terms are always invalid.
Peeking inside, we see the following.
proof_type.mli:
    and tactic = goal sigma -> (goal list sigma * validation)
    and validation = (proof_tree list -> proof_tree)
These are completely sensible types. However, is it necessary to make them public/non-abstract?
I'm not criticizing, I just wonder if I missed something. We use similar definitions in MetaPRL, but the tactic and validation types are abstract outside the kernel. This helps ensure that correctness depends only on the kernel/refiner, not on user code (modulo correctness of OCaml, which is wonderful and reliable).
Jason
Jason Hickey                  http://www.cs.caltech.edu/~jyh
Caltech Computer Science      Tel: 626-395-6568 FAX: 626-792-4257
