- To: Jean-Christophe Filliatre <Jean-Christophe.Filliatre AT lri.fr>
- Cc: coq-club AT pauillac.inria.fr, nogin AT cs.caltech.edu
- Subject: Re: [Coq-Club] Type safety
- Date: Fri, 11 Feb 2005 10:08:02 -0800
- Organization: Caltech
Jean-Christophe Filliatre wrote:
In the Coq architecture, the correctness is ensured at the kernel
level, once the proof is completed. To be more precise, the
validation above will build the proof term once the proof is done and
this proof term will be type-checked by the kernel.
Thanks, that makes perfect sense. We do a similar double-check in MetaPRL. To follow the soundness argument one step further, a programmer can always write a bad tactic, even a bad validation. However, a proof_tree can always be checked.
type proof_tree = {
open_subgoals : int;
goal : goal;
ref : (rule * proof_tree list) option }
In a complete proof, there must be no open_subgoals, and no ref=None. A proof_tree proves a goal if the goal has a type, and for each node in the tree the (goal, rule, subgoals) is a valid inference. Furthermore, 1) there are a small number of rules defined by the kernel, and 2) in each case, if the goal has a type then the subgoals have a type.
In the implementation of proof checking, what happens with terms in rule arguments? For example, for the rule (Cut (direction, id, <term>)), I assume the proof checker must perform a typecheck on <term>. Is this right?
Thanks,
Jason
Jason Hickey http://www.cs.caltech.edu/~jyh
Caltech Computer Science Tel: 626-395-6568 FAX: 626-792-4257
- [Coq-Club] Type safety, Jason Hickey
- Re: [Coq-Club] Type safety,
- Re: [Coq-Club] Type safety, Jason Hickey
