- To: vincent.chatel AT transport.alstom.com
- Cc: Benjamin Werner <benjamin.werner AT inria.fr>, Venanzio Capretta <venanzio AT site.uottawa.ca>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Re: [Coq-Club] Réf. : Re: [Coq-Club] prod list
- Date: Sat, 8 Oct 2005 23:22:35 +0200
In the same vein, see also Appendix B in the PhD of Pierre Corbineau:
he proves that given the inductive Type entry :=
mkE : forall X : set, X -> entry,
there is no coerce function of type forall X:Set, X -> option X
such that (coerce X (mkE X x)) reduces to (Some x).
JF
Benjamin Werner a ecrit :
> But the main point is that when you have a list of objects who can be
> of any type,
> like in these examples, you cannot do much with it. Basically, you
> can just apply the
> elements of the list to a polymorphic function (I.e. which takes
> arguments of any
> type). So these definitions are rarely used in practice, as far as I
> can think.
> Cheers,
> Benjamin
> > Regards
> > Vincent
> > You can do this:
> > Inductive poly_list: Type :=
> > poly_nil: poly_list
> > | poly_cons: forall X:Set, X -> poly_list -> poly_list.
> > Implicit Arguments poly_cons [X].
> > Check (poly_cons true (poly_cons 3 poly_nil)).
> > In the good old days when Set was impredicative you could have defined
> > it in Set instead of Types.
> > Cheers,
> > Venanzio
> > On Thu, 2005-06-10 at 17:11 +0200,
>Â >Â vincent.chatel AT transport.alstom.com
> > wrote:
> >> Hi Coq'ers,
> >> I would like to construct an inductive type like prod but such
> >> that all
> >> elements of this type finish by a final element.
> >> ( ) : 1
> >> (a,( )) : A * 1 (it's isomorph to A)
> >> (b,a,( )) : B *A *1
> >> It seems like a list but in a list I cannot mix elements with
> >> differents
> >> types.
> >> Thaks in advance
> >> Vincent
> > Bug reports: http://coq.inria.fr/bin/coq-bugs
> > Archives: http://pauillac.inria.fr/pipermail/coq-club
> > http://pauillac.inria.fr/bin/wilma/coq-club
> > Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
> > :._______________
> > CONFIDENTIALITE : Ce message et les éventuelles pièces attachées sont
> > confidentiels. Si vous n'êtes pas dans la liste des destinataires,
> > veuillez
> > informer l'expéditeur immédiatement et ne pas divulguer le contenu
> > à une
> > tierce personne, ne pas l'utiliser pour quelque raison que ce soit,
> > ne pas
> > stocker ou copier l'information qu'il contient sur un quelconque
> > support.
> > CONFIDENTIALITY : This e-mail and any attachments are
> > confidential and
> > may be privileged. If you are not a named recipient, please notify
> > the
> > sender immediately and do not disclose the contents to another
> > person, use
> > it for any purpose or store or copy the information in any medium.
- [Coq-Club] Réf. : Re: [Coq-Club] prod list, vincent . chatel
- [Coq-Club] Re: [Coq-Club] Réf. : Re: [Coq-Club] prod list,
Benjamin Werner
- Re: [Coq-Club] Re: [Coq-Club] Réf. : Re: [Coq-Club] prod list, jean-francois . monin
- Re: [Coq-Club] Réf. : Re: [Coq-Club] prod list, Venanzio Capretta
Benjamin Werner
