- To: Lionel Elie Mamane <lionel AT mamane.lu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: RE : Re: [Coq-Club]Type system in Coq
- Date: Wed, 7 Jun 2006 14:09:52 +0200 (CEST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.fr; h=Message-ID:Received:Date:From:Reply-To:Subject:To:Cc:In-Reply-To:MIME-Version:Content-Type:Content-Transfer-Encoding; b=Qf+c0Oc9YTSuATzoOWPRg48q+JYA9Rrvc80I8DnqlpW0k8fhUe6GIAdzrgp7LDIZht10p/46p5/HRBPvslQC7RkldB10MvUoVBnh96YLNrbhnLBvCJJH0OZpzDtikgCHeMhVRqcr9TLGV+79OArb+9ID+qqry7LtSvF8uHcmNwc= ;
Hello,
Thank you for the reply. Unfortunately my example was
too simplified compare to the original type system I
am dealing with. Here is a less simplified version.
Can you prove the goal?
Inductive Trm : Set :=
trm : nat->Trm.
Inductive Typ : Trm*nat->Set :=
axiom : forall n, Typ (trm n, n).
Goal forall t:Trm, forall n, forall x y:Typ (t,n),
x=y.
Fabrice
P.S. I also found that I can prove the goal in my
previous mail by using dependent equality, but it is
not enough to prove the above goal.
Require Export Eqdep.
trm : Trm.
Inductive Typ : Trm->Set :=
axiom : Typ trm.
Goal forall t:Trm, forall x y:Typ t, x=y.
induction t.
intros.
apply (eq_dep_eq Trm Typ).
induction x.
induction y.
apply eq_dep_intro.
__________________________________________________
Do You Yahoo!?
En finir avec le spam? Yahoo! Mail vous offre la meilleure protection
possible contre les messages non sollicités
http://mail.yahoo.fr Yahoo! Mail
- [Coq-Club]Type system in Coq, Fabrice Lemercier
- Re: [Coq-Club]Type system in Coq, Santiago Zanella Béguelin
Lionel Elie Mamane
- RE : Re: [Coq-Club]Type system in Coq, Fabrice Lemercier
- Re: RE : Re: [Coq-Club]Type system in Coq, Roland Zumkeller
- Re: RE : Re: [Coq-Club]Type system in Coq, Lionel Elie Mamane
- Re: RE : Re: [Coq-Club]Type system in Coq, Frederic Blanqui
