- From: "Eric Jaeger \(SGDN\)" <eric.jaeger AT sgdn.pm.gouv.fr>
- To: "Coq Club" <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club]using Set identity rather than Prop equality
- Date: Sun, 3 Sep 2006 15:01:27 +0200
- Organization: SGDN
Hi,
After some time working with Coq, I've chosen for one of my projects (in which I don't care about impredicativity or proof irrelevance, but have difficulties to "eliminate" Prop hypothesis with a Set goal) to work without using the Prop sort, but Set instead... It's of course fine for my definitions, etc. and I was happy to discover that tactics such as rewrite can use identity as well as equality. However, I still have difficulties to get rid of Prop - in particular as far as equality is concerned.
As an example, if for "S:Set" I define "Inductive ind_id:S->S->Set:=ii_intro:forall (a:S), ind_id a a", then the inversion tactic applied to an hypothesis "ind_id a b" will return "a=b", while I would prefer "identity a b".
Is there a solution to work with Coq without using Prop at all ? Or, at least, to have Coq generate indentity results instead of equality results ?
Thanks for any help, Eric Jaeger
- [Coq-Club]using Set identity rather than Prop equality, Eric Jaeger \(SGDN\)
- Re: [Coq-Club]using Set identity rather than Prop equality,
Hugo Herbelin
Eric Jaeger
- Re: [Coq-Club]using Set identity rather than Prop equality, Arnaud Spiwack
Eric Jaeger
- Re: [Coq-Club]using Set identity rather than Prop equality, Benjamin Werner
Hugo Herbelin
