- From: Benjamin Werner <benjamin.werner AT inria.fr>
- To: "Eric Jaeger (SGDN)" <eric.jaeger AT sgdn.pm.gouv.fr>
- Cc: "Coq Club" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club]using Set identity rather than Prop equality
- Date: Sun, 3 Sep 2006 21:05:40 +0200
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=beta; d=gmail.com; h=received:in-reply-to:references:mime-version:x-priority:content-type:message-id:cc:content-transfer-encoding:subject:date:to:x-mailer:from:sender; b=d1ZZyhOpasuIOTZs/U3o9X3c9pvfVtJ6G7/EIdQaugHUMdId1r30LInCcA+hrSqUQKdjmCAdGqoHN2KpvhP705Jnl5aa7wztfYnm1lLocuKUN9/bnn6yVjCmm6TAG2Sla4vRpOEcD6FdNFYMzWaCGezRh6C/CEpUh0O6QlpXDa4=
Hello,
In addition to Hugo's answer, note also that if you happen to be working in classical logic
(which then would be classical logic for Type) you can always lift your hypotheses from
Prop to Type, when you need to.
For instance:
Parameter EM : forall T : Type, T + (T->False).
Lemma lift_ex : forall A P, (exists x, P x) -> {x:A| P x}.
intros A P e; elim (EM {x:A| P x}); trivial; intro neg.
assert (f:False).
elim e; intros x p; apply neg; exists x; trivial.
elim f.
Qed.
Lemma lift_or : forall A B, A\/B -> {A}+{B}.
intros A B o; elim (EM ({A}+{B})) ; trivial; intros neg.
assert (f:False); try elim f.
elim o; auto.
Qed.
Cheers,
Benjamin
Le 3 sept. 06 à 15:01, Eric Jaeger (SGDN) a écrit :
Hi,
After some time working with Coq, I've chosen for one of my projects (in which I don't care about impredicativity or proof irrelevance, but have difficulties to "eliminate" Prop hypothesis with a Set goal) to work without using the Prop sort, but Set instead... It's of course fine for my definitions, etc. and I was happy to discover that tactics such as rewrite can use identity as well as equality. However, I still have difficulties to get rid of Prop - in particular as far as equality is concerned.
As an example, if for "S:Set" I define "Inductive ind_id:S->S- >Set:=ii_intro:forall (a:S), ind_id a a", then the inversion tactic applied to an hypothesis "ind_id a b" will return "a=b", while I would prefer "identity a b".
Is there a solution to work with Coq without using Prop at all ? Or, at least, to have Coq generate indentity results instead of equality results ?
Thanks for any help, Eric Jaeger
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club]using Set identity rather than Prop equality, Eric Jaeger \(SGDN\)
- Re: [Coq-Club]using Set identity rather than Prop equality,
Hugo Herbelin
Eric Jaeger
- Re: [Coq-Club]using Set identity rather than Prop equality, Arnaud Spiwack
Eric Jaeger
- Re: [Coq-Club]using Set identity rather than Prop equality, Benjamin Werner
Hugo Herbelin
