- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]using Set identity rather than Prop equality
- Date: Fri, 29 Sep 2006 21:25:09 +0200
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=beta; d=gmail.com; h=received:message-id:date:from:user-agent:mime-version:to:subject:references:in-reply-to:content-type:content-transfer-encoding:sender; b=jD3Bk66ofv65isckdMkojvmQiKj5/2Emvn9/DiecDyUYtmUDj/ICzRmZDmP8P3ceujIudV8VM9oDTz2kNUcgEFlmjwnfPCbeW2c1a43U5dHFfPWi7iZ2cIsLOGQdz/lr+T7HtdYYBywjbcfSU13nxkxQZJXkvjXvAvjo8iHWNmo=
Without checking whether I'm right or not :
The rewrite tactics in the left-to-right direction needs an elimination principle called /inductivename/_rec_r (r is for reverse I reckon). In your case it would be inductive_rec_r . To prove the right rec_r lemma. Search the standard library for eq_rec_r ( Check eq_rec_r ).
I insist on the fact that the name of the statement matters.
Arnaud Spiwack
Eric Jaeger a écrit :
Thanks for the tactic "inversion_set", it is really useful. But I'm now
facing a small problem, that appears to me as a weird behaviour of the
rewrite tactic (with Notation "A _= B":=(@identity _ A B) (no associativity,
at level 70) where "_=" is the UTF-8 equiv):
H:d<='i (* <= is a notation for an inductive dependant type in Set *)
i0:d_=si
(some term in which d occurs free as well)
"rewrite i0 in H" causes an error "User error: the type of elimination
clause is not well-formed" (while the goal, hypothesis and the type T of d
and i all inhabit Set). The strangest thing however is that to make the
rewrite, it is sufficient is such case to use instead "rewrite <- (sym_id
i0) in H".
Any clue?
Best Regards, Eric Jaeger
rewriteAfter some time working with Coq, I've chosen ... to work without
using the Prop sort, but Set instead... It's of course fine for my
definitions, etc. and I was happy to discover that tactics such as
tocan use identity as well as equality. However, I still have difficulties
rename H' into H).get rid of Prop - in particular as far as equality is concerned.The definitions of eq and identity are equivalent. So, a possibility
As an example, if for "S:Set" I define "Inductive
ind_id:S->S->Set:=ii_intro:forall (a:S), ind_id a a", then the inversion
tactic applied to an hypothesis "ind_id a b" will return "a=b", while I
would prefer "identity a b".
is to (superficially) hack inversion so that it generates equalities
using identity rather than eq (see below). This remains superficial as
the proof term still explicitly refers to eq.
Alternatively, some approximation of inversion relying on identity
could be rewritten in ltac.
Ltac repeat_on_hyps f := repeat (match goal with [ H:_ |- _ ] => f H end).
Ltac coerce3 f H := let H':= fresh in (assert (H':=f _ _ _ H); clear H;
Ltac inversion_set c := inversion c; repeat_on_hyps ltac:(coerce3 eq_id).
Variable S:Set.
Inductive ind_id:S->S->Set:=ii_intro:forall (a:S), ind_id a a.
Goal forall x y, ind_id x y -> ind_id y x.
intros x y H.
inversion_set H.
x : S
y : S
H : ind_id x y
a : S
H1 : identity x y
H0 : identity a x
ind_id y y
Hugo Herbelin
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club]using Set identity rather than Prop equality, Eric Jaeger \(SGDN\)
- Re: [Coq-Club]using Set identity rather than Prop equality,
Hugo Herbelin
Eric Jaeger
- Re: [Coq-Club]using Set identity rather than Prop equality, Arnaud Spiwack
Eric Jaeger
- Re: [Coq-Club]using Set identity rather than Prop equality, Benjamin Werner
Hugo Herbelin
