coq-club - Re: [Coq-Club]Nested datatypes in Coq
chronological Thread
  • To: Robert Dockins <robdockins AT fastmail.fm>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club]Nested datatypes in Coq
  • Date: Mon, 6 Nov 2006 14:53:36 +0900
Hello Rob,
Thanks to everyone who replied. I see that the above POPLmark solution uses
the development branch of Coq and the new support for these kinds of
inductive terms as mentioned by Ralph Matthes. That just gives me another
reason to anticipate the new release :-)
It appears that the current version of the experimental command "Function" cannot go through the definition of gfoldT. It returns the following error message:
  failure in proveterminate
  User error: find_call_occs : Lambda
See below my code "Example 1" (It needs the development version of today -- version 9340).
Also I tried to defined joinT directly (i.e. without using gfoldT). See below my code "Example 2". But then I ran into universe inconsistencies!
It is very likely that my direct definition of joinT is wrong. However I have the feeling that the lack of universe polymorphism in Coq prevent one to formalize properly nested datatypes.
Do you too run into universe inconsistencies?
Best,
David
(******* Example 1 *******)
Require Import Recdef.
Set Implicit Arguments.
Inductive Incr (A:Type) : Type :=
  zero : Incr A
| succ : A->Incr A.
Inductive Trm : Type->Type :=
  var : forall A, A->Trm A
| app : forall A, Trm A->Trm A->Trm A
| lam : forall A, Trm (Incr A) -> Trm A.
Definition mapI (A B:Type)(f:A->B)(x:Incr A) : Incr B :=
  match x with
    zero => zero B
  | succ x' => succ (f x')
  end.
Fixpoint mapT (A B:Type)(f:A->B)(t:Trm A) {struct t} : Trm B :=
  match t in (Trm T) return ((T -> B) -> Trm B) with
    var _ x => fun f' => var (f' x)
  | app _ t1 t2 => fun f' => app (mapT f' t1) (mapT f' t2)
  | lam _ t' => fun f' => lam (mapT (mapI f') t')
  end f.
Fixpoint mesT (A:Type)(t:Trm A) {struct t} : nat :=
  match t with
    var _ _ => 0
  | app _ t1 t2 => mesT t1 + mesT t2
  | lam _ t' => mesT t' + 1
  end.
Function gfoldT
  (A B:Type)(M N:Type->Type)
(v:forall A, M A->N A)(a:forall A, N A->N A->N A)(l:forall A, N (Incr A)->N A)
  (k:forall A, Incr (M A)->M (Incr A))
  (t:Trm A) {measure mesT t} : A=M B -> N B :=
  match t in (Trm T) return (T = M B -> N B) with
    var A0 x =>
      fun H : A0 = M B =>
        v B (eq_rect A0 (fun T : Type => T) x (M B) H)
  | app A0 t1 t2 =>
      fun H : A0 = M B =>
        a B (gfoldT (A:=A0) B M N v a l k t1 H)
            (gfoldT (A:=A0) B M N v a l k t2 H)
  | lam A0 t' =>
      fun H : A0 = M B =>
        l B (gfoldT (A:=(M (Incr B))) (Incr B) M N v a l k
              (mapT
                (k B)
                ((fun t'0 : Trm (Incr (M B)) => t'0)
(eq_rect A0 (fun A1 : Type => Trm (Incr A1)) t' (M B) H)))
              (refl_equal (M (Incr B))))
         end.
(******* Example 2 *******)
  zero : Incr A
| succ : A->Incr A.
  match x with
    zero => zero B
  end.
  end f.
Definition distT (A:Type)(x:Incr (Trm A)) : Trm (Incr A) :=
  match x with
    zero => var (zero A)
  | succ x' => mapT (succ (A:=A)) x'
  end.
Definition joinT (A:Type)(t:Trm A)(B:Type)(H:A=Trm B) : A.
Proof.
fix 2.
intros A t.
destruct t as [C x| C t1 t2| C t']; intros B H.
apply x.
rewrite H in |- *.
  apply app.
  eapply joinT.
  rewrite <- H in |- *.
    apply t1.
reflexivity.
eapply joinT.
   apply t2.
reflexivity.
rewrite H in |- *.
  apply lam.
   eapply joinT.
apply (mapT (distT (A:=B))).
   apply t'.
reflexivity.
Defined.
David Nowak
http://staff.aist.go.jp/david.nowak/
