- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club]Nested datatypes in Coq
- Date: Mon, 06 Nov 2006 07:25:30 -0800
Robert Dockins wrote:
If I understand the situation correctly, there isn't any way at all to define a function with this type if Term is in sort Type. Actually, you could replace Term with _any_ definition in sort Type and this would still be impossible. It is also my understanding that if I could magically make Coq accept the Term definition in sort Set that these problems would go away. Is all that right?That's correct, with the right magic. The bit of magic that you're looking for is the "-impredicative-set" command-line flag. With it, you can replace all instances of Type with Set in your example (and add type annotations on a few forall's, since Type is chosen by default for any variable that is used as a type) and it should work swimmingly.
The big gotcha is that your main types are "large," so you won't be able to eliminate their values to form others in sort Type. I haven't tried your whole example to see if that would cause problems. The other gotcha is that some people are uncomfortable with the idea of impredicativity and will question the validity of any results you derive, but I've found impredicativity to be so useful for formalizing programming languages that I ignore this last point. :)
- [Coq-Club]Nested datatypes in Coq, Robert Dockins
- Re: [Coq-Club]Nested datatypes in Coq,
roconnor
Robert Dockins
David Nowak
Robert Dockins
jean-francois . monin
- Re: [Coq-Club]Nested datatypes in Coq, Robert Dockins
- Re: [Coq-Club]Nested datatypes in Coq, Adam Chlipala
- Re: [Coq-Club]Nested datatypes in Coq, roconnor
Robert Dockins
David Nowak
Robert Dockins
- Re: [Coq-Club]Nested datatypes in Coq, Stefan Monnier
roconnor
