- To: Robert Dockins <robdockins AT fastmail.fm>
- Cc: David Nowak <david.nowak AT aist.go.jp>, Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club]Nested datatypes in Coq
- Date: Mon, 6 Nov 2006 16:01:30 +0100
Robert Dockins a ecrit :
> > Do you too run into universe inconsistencies?
> I did. Adding the definition of distT to the development I posted in
> my last email gives rise to universe inconsistencies. I tried a
> number of workarounds, including adding a duplicate definition of
> terms under a different name, but I couldn't get anything to work.
> I think you might be right about universe polymorphism. The goal is
> to define the join operation, which has type:
> forall A:Type, Term (Term A) -> Term A
> If I understand the situation correctly, there isn't any way at all
> to define a function with this type if Term is in sort Type.
> Actually, you could replace Term with _any_ definition in sort Type
> and this would still be impossible.
Not quite:
Inductive Term (A:Type) : Type := TI : A -> A -> Term A.
Definition p1 : forall A:Type, Term (Term A) -> Term A.
intros A (x,y); exact x.
Defined.
Of course your example is more complex...
Best,
Jean-François Monin Univ. Joseph Fourier, GRENOBLE
VERIMAG - Centre Equation http://www-verimag.imag.fr/~monin/
2 avenue de Vignate tel (+33 | 0) 4 56 52 04 39
F-38610 GIERES fax (+33 | 0) 4 56 52 03 40
- [Coq-Club]Nested datatypes in Coq, Robert Dockins
- Re: [Coq-Club]Nested datatypes in Coq,
roconnor
Robert Dockins
David Nowak
Robert Dockins
- Re: [Coq-Club]Nested datatypes in Coq, jean-francois . monin
- Re: [Coq-Club]Nested datatypes in Coq, Robert Dockins
- Re: [Coq-Club]Nested datatypes in Coq, Adam Chlipala
- Re: [Coq-Club]Nested datatypes in Coq, roconnor
Robert Dockins
David Nowak
Robert Dockins
- Re: [Coq-Club]Nested datatypes in Coq, Stefan Monnier
roconnor
