- From: "Brian E. Aydemir" <baydemir AT cis.upenn.edu>
- To: coq-club AT pauillac.inria.fr
- Cc: Sean Wilson <sean.wilson AT ed.ac.uk>
- Subject: Re: [Coq-Club]Problems writing programs with tactics
- Date: Tue, 5 Dec 2006 09:57:38 -0500
On Dec 5, 2006, at 9:14 AM, Sean Wilson wrote:
Hi,
I have a couple of questions about programming in Coq that I cannot seem to
work out. As an example of my issue, I want to program a list 'take' function
that takes items n from the front of a list e.g. take [1,2,3] 1 = [1] and
take [1,2,3] 2 = [1,2]. In ML, you might implement it with:
fun take (_, 0) = [ ]
| take ([ ], _) = raise Subscript
| take (h :: t, n) = h::take (t, n – 1) handle Overflow => raise Subscript
You can write a similar version directly in Coq, but I'm interested in how to
write it using only the tactic language (I find this easier when I need to
use dependently typed terms). Here is one of my attempts:
Definition take : forall (x:list nat) (n:nat), list nat.
intros.
induction n.
apply (nil:list nat). (* Counter is zero *)
induction x.
apply (nil:list nat).(* This case shouldn't happen; return nil by default *)
apply (cons a IHn). (* Recursive call *)
Qed.
The actual Coq term produced isn't very readable, so here is the extracted
version:
let rec take x = function
| O -> Nil
| S n0 ->
(match x with
| Nil -> Nil
| Cons (a, l) -> Cons (a, (take x n0)))
This is wrong: the last match clause should be Cons (a, (take l n0))). The
counter is getting smaller each recursive call but the list is not. If I use
"apply (cons a IHx)" instead, only the list gets smaller each call; I need
both to get smaller for it to work but none of the terms in the hypothesis
does this. I can get the result I want by using the refine tactic:
Definition take2 : forall (x:list nat) (n:nat), list nat.
refine (fix take2 (x:list nat) (n:nat) {struct n} : list nat := _).
(* Same as above up to the last line... *)
apply (cons a (take2 x n)).
Qed.
Is there any way to get this result without using refine? I'd like to know if
there was a way to do this.
I think the following works.
Definition take : forall (n:nat) (x:list nat), list nat.
intros n; induction n.
(* n = 0 *)
intros; exact nil.
(* n = S m, for some m *)
intros x; case x.
(* x = nil, shouldn't happen *)
exact nil.
(* x = z :: zs *)
intros z zs.
exact (z :: IHn zs).
Defined.
Extraction take.
let rec take n x =
match n with
| O -> Nil
| S n0 ->
(match x with
| Nil -> Nil
| Cons (z, zs) -> Cons (z, (take n0 zs)))
The main difference is where the (x:list nat) gets quantified. You want an induction hypothesis here that works for any list, not some particular fixed one. This requires that the list be quantified in the goal when you perform the induction.
Closer to the actual example I want to do is this, using a sigma type to
constrain the value of the counter:
Definition take3 : forall (x:list nat) (n:{i:nat | i <= length (x)}), list nat.
refine (fix take2 (x:list nat) (n:{i:nat | i <= length(x)}) {struct n} : list
nat := _).
destruct n as [n].
induction n.
induction x.
apply (nil:list nat). (* error *)
(* Construct the counter term (with proof) for the recursive call *)
assert({i : nat | i <= length x}).
exists n.
intuition.
apply (cons a (take3 x H)).
Qed.
I think the following does what you want for this version. Admittedly, I used refine, but only because I didn't feel like building up the "sigma term" by hand. Here, it made more sense to me to define the function by induction on x and then use what I know about x in each case to learn something about n, since n depends on x and not the other way around.
Definition take3 : forall (x:list nat) (n:{i:nat | i <= length(x)}), list nat.
intros x; induction x as [ | x xs IH ].
(* case: nil *)
intros; exact nil.
(* case: cons x xs *)
simpl.
intros (i, pf). induction i as [ | i' _ ].
(* subcase: i = 0 *)
exact nil.
(* subcase: i = S i' *)
assert (i' <= length xs). auto with arith.
refine (x :: IH _). exists i'. exact H.
Defined.
Extraction take3.
let rec take3 l n =
match l with
| Nil -> Nil
| Cons (a, l0) ->
(match n with
| O -> Nil
| S n0 -> Cons (a, (take3 l0 n0)))
Hope that helps,
Brian
- [Coq-Club]Problems writing programs with tactics, Sean Wilson
- Re: [Coq-Club]Problems writing programs with tactics, Brian E. Aydemir
- Re: [Coq-Club]Problems writing programs with tactics, jean-francois . monin
