- To: Sean Wilson <sean.wilson AT ed.ac.uk>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Problems writing programs with tactics
- Date: Tue, 5 Dec 2006 21:32:02 +0100
You can adapt Laurent's solution to the dependent version.
It is better to use a reducible definition of less_or_equal
(no arith, no inversion, etc.):
Fixpoint LE (n m:nat) {struct n} : Prop :=
match n, m with
| O, _ => True
| (S n), O => False
| (S n), (S m) => LE n m
end.
Definition take3 :
forall (x:list nat) (n: {i: nat | LE i (length x)}), list nat.
fix 1.
intros l ([| i], H).
exact nil.
destruct l as [|h t]; simpl in * |-*.
case H.
apply (cons h). apply (take3 t). exists i; exact H.
Defined.
Or even:
Definition take4 : forall (l:list nat) (n:nat), LE n (length l) -> list nat.
fix 1.
intros l [| n].
intros _; exact nil.
destruct l as [|h t]; simpl; intro H.
case H.
exact (h :: take4 t n H).
Defined.
Hope this helps,
JF
Jean-François Monin Univ. Joseph Fourier, GRENOBLE
VERIMAG - Centre Equation http://www-verimag.imag.fr/~monin/
2 avenue de Vignate tel (+33 | 0) 4 56 52 04 39
F-38610 GIERES fax (+33 | 0) 4 56 52 03 40
- [Coq-Club]Problems writing programs with tactics, Sean Wilson
- Re: [Coq-Club]Problems writing programs with tactics, Brian E. Aydemir
- Re: [Coq-Club]Problems writing programs with tactics, jean-francois . monin
