- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club]Problems writing programs with tactics
- Date: Tue, 5 Dec 2006 14:14:25 +0000
- Organization: School of Informatics, The University of Edinburgh
Hi,
I have a couple of questions about programming in Coq that I cannot seem to
work out. As an example of my issue, I want to program a list 'take' function
that takes items n from the front of a list e.g. take [1,2,3] 1 = [1] and
take [1,2,3] 2 = [1,2]. In ML, you might implement it with:
fun take (_, 0) = [ ]
| take ([ ], _) = raise Subscript
| take (h :: t, n) = h::take (t, n – 1) handle Overflow => raise Subscript
You can write a similar version directly in Coq, but I'm interested in how to
write it using only the tactic language (I find this easier when I need to
use dependently typed terms). Here is one of my attempts:
Definition take : forall (x:list nat) (n:nat), list nat.
intros.
induction n.
apply (nil:list nat). (* Counter is zero *)
induction x.
apply (nil:list nat).(* This case shouldn't happen; return nil by default *)
apply (cons a IHn). (* Recursive call *)
Qed.
The actual Coq term produced isn't very readable, so here is the extracted
version:
let rec take x = function
| O -> Nil
| S n0 ->
(match x with
| Nil -> Nil
| Cons (a, l) -> Cons (a, (take x n0)))
This is wrong: the last match clause should be Cons (a, (take l n0))). The
counter is getting smaller each recursive call but the list is not. If I use
"apply (cons a IHx)" instead, only the list gets smaller each call; I need
both to get smaller for it to work but none of the terms in the hypothesis
does this. I can get the result I want by using the refine tactic:
Definition take2 : forall (x:list nat) (n:nat), list nat.
refine (fix take2 (x:list nat) (n:nat) {struct n} : list nat := _).
(* Same as above up to the last line... *)
apply (cons a (take2 x n)).
Qed.
Is there any way to get this result without using refine? I'd like to know if
there was a way to do this.
Closer to the actual example I want to do is this, using a sigma type to
constrain the value of the counter:
Definition take3 : forall (x:list nat) (n:{i:nat | i <= length(x)}), list nat.
refine (fix take2 (x:list nat) (n:{i:nat | i <= length(x)}) {struct n} : list
nat := _).
destruct n as [n].
induction n.
induction x.
apply (nil:list nat). (* error *)
(* Construct the counter term (with proof) for the recursive call *)
assert({i : nat | i <= length x}).
exists n.
intuition.
apply (cons a (take3 x H)).
Qed.
This is the same as the previous example with refine except there is a little
more work in taking apart and building sigma type terms for the counter.
However, I get an error at the Qed. Coq says:
Recursive call to take3 has principal argument equal to
"exist (fun i : nat => i <= length l2) n2
(let H :=
let H :=
fun _ : n2 <= length l2 =>
let H1 := F0 l2 (fun _ : n2 <= length l2 => l2) in l2 in
F0 l2 H in
lt_n_Sm_le n2 (length l2) l3)"
instead of a subterm of n
I suspect that this is because what I said was my structurally recursive
parameter is not accurate. What I really want to say in the "refine" line is
that take3 is structurally recursive on the first member of the pair that is
n. I tried to do this with:
(proj1_sig
n)} : list nat := _).
Coq gives this error:
"Syntax error: [Prim.name] expected after 'struct' (in [fixannot])"
How can I get this to work?
Any help would be greatly appreciated.
Regards,
Sean
- [Coq-Club]Problems writing programs with tactics, Sean Wilson
- Re: [Coq-Club]Problems writing programs with tactics, Brian E. Aydemir
- Re: [Coq-Club]Problems writing programs with tactics, jean-francois . monin
