coq-club - Re: [Coq-Club]automatically entering proof mode and inlining proofs
chronological Thread
  • To: "Ryan J. Wisnesky" <ryan AT eecs.harvard.edu>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]automatically entering proof mode and inlining proofs
  • Date: Mon, 26 Feb 2007 14:35:50 +0100
Le Thu, 22 Feb 2007 18:23:04 -0500,
"Ryan J. Wisnesky"
 a écrit :
> Hello,
> I'm wondering if there is a way to automatically switch between
> writing a term and the interactive theorem proving mode.  That is, I
> have a function that takes as an argument a proof that some condition
> holds; when I'm writing a program that uses this function, I need to
> construct proofs "on the fly" while writing other functions.  In
> other words, I have something like
> Definition f (A B:Set) (pf: A->B) : .. := ....
You can define a function with tactics by no giving its definition:
Definition f (A B:Set) (pf: A->B) : ..  .
intros.
Defined.
Don't forget to end the definition by "Defined" otherwise the function
body will be hidden.
Once in the tactic mode you can use the refine tactic.
So I would say that you can do the following:
Definition h : <typofh>.
refine
  (let g f nat nat _ in
   complicated thing).
(* Here you should left with the proof that A->B *)
Defined. (* not Qed.*)
Cheers
Pierre Courtieu
> later, I want to use this function:
> Definition h = let g = f nat nat (proof for nat->nat) in complicated
> thing
> Right now, I can declare a term x and write
> let g = f nat nat x in something.
