- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]automatically entering proof mode and inlining proofs
- Date: Mon, 26 Feb 2007 16:34:48 +0100
- Organization: LRI
Le vendredi 23 février 2007 00:23, Ryan J. Wisnesky a écrit :
> Hello,
> I'm wondering if there is a way to automatically switch between writing a
> term and the interactive theorem proving mode. That is, I have a function
> that takes as an argument a proof that some condition holds; when I'm
> writing a program that uses this function, I need to construct proofs "on
> the fly" while writing other functions. In other words, I have something
> like
> Definition f (A B:Set) (pf: A->B) : .. := ....
> later, I want to use this function:
> Definition h = let g = f nat nat (proof for nat->nat) in complicated thing
> Right now, I can declare a term x and write
> let g = f nat nat x in something.
> and then I can prove x separately. The downside of this is that I have to
> reassume the context where x appears. Is there any way to switch into
> theorem proving mode while defining a function, or to somehow but in a
> bunch of "placeholders" and then prove the theorems later, and the have the
> proofs inlined, so as not to need break the proofs out as separate terms
> but still be able to take advantage of the interactive prover?
This is possible using the Program tactic I developed in v8.1, by writing:
Program Definition h = let g := f nat nat _ in ...
It will generate an obligation to show that (nat -> nat) in the appropriate
context (actually, it may not be exactly the one you'd expect, but that's
another problem). You can prove the obligation using:
Next Obligation.
<script>
Qed or Defined depending if you want inlining or not (definitely Defined if
it
is used in a Fixpoint definition). Once all obligations are solved you get a
usual Coq definition. There is a short documentation in the manual describing
the commands.
Disclaimer: you may encounter a bug, but I'd be glad to hear about it !
Matthieu Sozeau
http://www.lri.fr/~sozeau
- [Coq-Club]automatically entering proof mode and inlining proofs, Ryan J. Wisnesky
- Re: [Coq-Club]automatically entering proof mode and inlining proofs,
Pierre Courtieu
Ryan J Wisnesky.
- Re: [Coq-Club]automatically entering proof mode and inlining proofs, Pierre Courtieu
- Re: [Coq-Club]automatically entering proof mode and inlining proofs, Thery Laurent
frédéric BESSON
- Re: [Coq-Club]automatically entering proof mode and inlining proofs, Matthieu Sozeau
- Re: [Coq-Club]automatically entering proof mode and inlining proofs, Ryan J. Wisnesky
Ryan J Wisnesky.
Pierre Courtieu
