- From: "Ryan J Wisnesky." <ryan AT eecs.harvard.edu>
- To: "Pierre Courtieu" <pierre.courtieu AT cnam.fr>
- Cc: "Ryan J. Wisnesky" <ryan AT eecs.harvard.edu>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]automatically entering proof mode and inlining proofs
- Date: Mon, 26 Feb 2007 14:29:22 -0500 (EST)
- Importance: Normal
Thanks for your reply. I think I may have given a confusing example, so
let me elaborate.
Here's a head of list function that requires a proof that its input list
has at least one element:
Require Import List.
Require Import Le.
Definition hd (A:Set) (l : list A) :=
match l return (length l > 0 -> A) with
| nil => fun H : length nil > 0 => False_rec A (le_Sn_O 0 H)
| a :: _ => fun _ => a
end.
To use this function on a given list, it is necessary to construct a proof
that the list has at least one element:
Definition l := cons 1 nil.
Definition prp : length l > 0 := le_n 1.
Now, we can take the hd of l:
Eval compute in (hd nat l prp).
= 1
: nat
What I am trying to figure out is if it is possible to write something
like the following (please excuse my newbie syntax):
Definition f (l2: list nat) : option nat :=
if length l2 > 0
just (hd nat l2 ??)
else
nothing
In this definition, ?? needs to be a proof that the length of l2 is
greater than 0. Ideally, because this proof occurs inside an if branch
where length l2 > 0 is true, I'd like to automatically enter the theorem
prover and trivially show that l2 is true in this context, or, to replace
?? with a variable corresponding to a verification condition to be proven
later. Currently, I have to either write a term for ?? by hand as I'm
writing the definition of f, or I have to replace ?? with a variable and
then define that variable after I've written f.
Does this make sense? Any thoughts are greatly appreciated.
Regards,
Ryan
> Le Thu, 22 Feb 2007 18:23:04 -0500,
> "Ryan J. Wisnesky"
>Â <ryan AT eecs.harvard.edu>
> a écrit :
>> Hello,
>> I'm wondering if there is a way to automatically switch between
>> writing a term and the interactive theorem proving mode. That is, I
>> have a function that takes as an argument a proof that some condition
>> holds; when I'm writing a program that uses this function, I need to
>> construct proofs "on the fly" while writing other functions. In
>> other words, I have something like
>> Definition f (A B:Set) (pf: A->B) : .. := ....
> You can define a function with tactics by no giving its definition:
> Definition f (A B:Set) (pf: A->B) : .. .
> intros.
> Defined.
> Don't forget to end the definition by "Defined" otherwise the function
> body will be hidden.
> Once in the tactic mode you can use the refine tactic.
> So I would say that you can do the following:
> Definition h : <typofh>.
> refine
> (let g f nat nat _ in
> complicated thing).
> (* Here you should left with the proof that A->B *)
> Defined. (* not Qed.*)
> Cheers
> Pierre Courtieu
>> later, I want to use this function:
>> Definition h = let g = f nat nat (proof for nat->nat) in complicated
>> thing
>> Right now, I can declare a term x and write
>> let g = f nat nat x in something.
- [Coq-Club]automatically entering proof mode and inlining proofs, Ryan J. Wisnesky
- Re: [Coq-Club]automatically entering proof mode and inlining proofs,
Pierre Courtieu
- Re: [Coq-Club]automatically entering proof mode and inlining proofs, Ryan J Wisnesky.
- Re: [Coq-Club]automatically entering proof mode and inlining proofs, Pierre Courtieu
- Re: [Coq-Club]automatically entering proof mode and inlining proofs, Thery Laurent
frédéric BESSON
- Re: [Coq-Club]automatically entering proof mode and inlining proofs, Matthieu Sozeau
- Re: [Coq-Club]automatically entering proof mode and inlining proofs, Ryan J. Wisnesky
Pierre Courtieu
