coq-club - Re: [Coq-Club]Representation question (and what can Program do about it)
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]Representation question (and what can Program do about it)
  • Date: Tue, 6 Mar 2007 11:34:13 +0100
  • Organization: LRI
Le mardi 06 mars 2007 00:20, Sean Wilson a écrit :
> Hi,
Hi,
> Given the usual definition for lists indexed by length:
> Inductive vect [A:Set] : nat -> Set :=
> | nil : (vect A O)
> | cons : (x:A)(n:nat)(vect A n)->(vect A (S n)).
> Can anyone explain what the difference is between using terms of this type
> and terms of type {x:list A | length = n}, particularly in the domain of
> writing certified programs (e.g. in the specification of a
> head/tail/take/append function)? When and why would you pick one
> representation over the other?
They're equivalent representations in Coq, i.e. you can easily build
vect A n <-> {x : list A | length x = n}.
Extraction-wise they're different as in the first case you will have the
length of the sublist appearing at each cons node while in the second version
it won't appear in the list structure ; rather, each list will be accompanied
by its length (other systems allow one not to keep the index during
conversion and/or extraction, so this may be a moot point).
Specification-wise it can certainly be argued that one or the other is the
most elegant but the real problem is that Coq has no built-in support for
either styles, especially it lacks built-in heterogeneous equality hence you
can't write " v : vect (n + 0), v': vect n |- v = v' ", while " v JMeq v' "
is OK and in contexts where "n + 0 = n" you will be able to get the leibniz
equality out. Similarly, it has no intrinsic support for subsets hence you're
forced to write proof-modifying code, which is almost always ugly and
impratical. So if you need to stay in Coq proper i would advise using the
good old simple types specification style instead.
<publicity length="long">
  Using the Program vernacular, the situation changes a bit:
  When using subsets with the Program vernacular, you will be able to write:
 Program Fixpoint app (l : list A) (l' : list A) { struct l } :
    { r : list A | length r = length l + length l' } :=
    match l with
      | nil => l'
      | hd :: tl => hd :: (tl ++ l')
    end
    where "x ++ y" := (app x y).
  Next Obligation.
    destruct_call app ; subtac_simpl.
  Defined.
  Program Lemma app_id_r : forall x (l : { l : list A | length l = x }),
        (`l) = app l nil.
    intros.
    subtac_simpl.
    induction x0 ; simpl ; auto.
    rewrite <- IHx0 ; reflexivity.
  Qed.
  This works because we are comparing vectors as if they were lists, ignoring
the index (` is the first projection for subset types). On the other hand,
Program also has support for working with dependent inductives, you can have
for example:
Set Implicit Arguments.
Variable A : Type.
(* Inverse vectors *)
Inductive tcev : nat -> Type :=
| vnil : tcev 0
| vcons : forall n, tcev n -> A -> tcev (S n).
Program Fixpoint app (n : nat) (v : tcev n) (m : nat) (v' : tcev m) { struct
v' } : tcev (n + m) :=
  match v' with
    | vnil => v
    | vcons n'' v'' x => app (vcons v x) v''
  end.
This definition can't be accepted by the Fixpoint command because in the
first
case v is of type "tvec n" while something of type "tvec (n + ?)" is
required. Program solves the problem by adding the appopriate coercions here,
and begs for a proof that " m = 0 -> JMeq v' vnil -> n = n + m " which is
trivially solved.
Now, you need to use heterogeneous equality to relate objects of type tcev:
Require Import JMeq.
Require Import Coq.subtac.Utils.
Lemma app_id_r_JMeq : forall n (v : tcev n), JMeq (app v vnil) v.
Proof.
  intros.
  induction v ; simpl ; auto ; elim_eq_rect ; simpl ; auto.
Qed.
Alternatively you can define:
Program Definition app_id_r_stmt (n : nat) (v : tcev n) := app v vnil = v.
Here a coercion is applied to v to put it in the 'tcev (n + 0)' type.
Lemma app_id_r : forall n (v : tcev n), app_id_r_stmt v.
Proof.
  red ; simpl ; intros.
  elim_eq_rect.
  rewrite (proof_irrelevance _ t (app_id_r_stmt_obligation_1 v)).
  reflexivity.
Qed.
In this second case, you will need to use proof irrelevance and elimination
of
eq_rect to use app_id_r as well. Actually, all this business require fiddling
with eq_rect and proof-irrelevance (only PI for subsets) which is not very
nice but can surely be better automated. On another note, it becomes
impossible to compute when using dependently typed functions where coercions
appear because of the irreducible eq_rect calls. OTOH, you can usually
compute with functions using subset types when using a lazy strategy.
My small experience with this is that subsets are good for
pre/post-conditions
and pushing invariants on subojects in datastructures while dependent
inductives shine when you need 'whole-structure' indexes and use
index-modifying operations.
Disclaimer: anything may change in Program and support for dependent
inductive
types is only available using the current svn version (which may be broken as
well).
Sorry for the long answer but I think it might be useful to others as well.
</publicity>
Matthieu Sozeau
http://www.lri.fr/~sozeau
