coq-club - Re: [Coq-Club]Representation question
chronological Thread
  • To: mulhern <mulhern AT gmail.com>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club]Representation question
  • Date: Tue, 13 Mar 2007 12:04:25 -0400 (EDT)
On Mon, 12 Mar 2007, mulhern wrote:
Secretly, my inductive constructor actually is like this:
Inductive mytype : Set :=
| Ground : mytype
| Cons : {x : list mytype | length (A := mytype) x = bound} -> mytype
And it's that implicit occurence of mytype that is causing all the trouble.
I had exactly the same problem. See the ``Defintion of Term'' section in my paper at <http://r6.ca/Goedel/goedel1.html#FOCL>. I end up useing mutually inductive types, but later I learn that one can use Vectors and define your own elimination scheme using nested fixed point. By using Vectors you can reuse the existing Vector library.
Many people complain that using Vectors is difficult. It is true if you are doing things like concatinating lists. For my purposes they worked fine because I never have to do these sorts of operations. All I do is make sure that the correct number of arguments to functions of a given arity.
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
