- To: mulhern <mulhern AT gmail.com>
- Cc: Sean Wilson <sean.wilson AT ed.ac.uk>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Representation question
- Date: Tue, 13 Mar 2007 09:46:35 +0100 (CET)
On Mon, 12 Mar 2007, mulhern wrote:
Inductive mytype : Set :=
| Ground : mytype
| Cons : {x : list mytype | length (A := mytype) x = bound} -> mytype
And it's that implicit occurence of mytype that is causing all the trouble.
note that, with Cons:list mytype->mytype, coq outputs no error but does not generate the good induction principle. this is because coq does not recognize list as a monotone type constructor and hence the occurrence of mytype in (list mytype) as a positive occurrence. you can however redefine it. see http://color.loria.fr/doc/Rewriting.Term.Varyadic.VTerm.html for an example of re-definition. http://color.loria.fr/doc/Rewriting.Term.WithArity.ATerm.html uses the same trick with vector instead of list. unfortunately, this does not seem possible in your case since coq outputs an error. by the way, you may be interested in a library on vectors. see http://color.loria.fr/doc/Rewriting.Util.Vector.VecUtil.html.
- [Coq-Club]Representation question, Sean Wilson
- Re: [Coq-Club]Representation question (and what can Program do about it), Matthieu Sozeau
- Re: [Coq-Club]Representation question,
mulhern
- Re: [Coq-Club]Representation question, Frederic Blanqui
roconnor
