- To: Adam Chlipala <adamc AT cs.berkeley.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Defining function with dependent structure in goal
- Date: 13 Mar 2007 18:03:46 +0000
- Source-info: From (or Sender) name not authenticated.
On Mar 12 2007, Adam Chlipala wrote:
Here's an example for a significantly simpler inversion dilemma that I've encountered. Advice from others on how to improve this implementation would be very interesting to me!
For those who might be interested in the problem I posed earlier, here is a solution, cooked up by the Nottingham team, that computes as desired. I hope others may find it useful.
Definition method (n m : nat ) (H : n = m) (P : n = m -> Set) :Set.
intros n m .
case n; case m.
intros. exact (P (refl_equal 0)). intros; exact unit. intros ; exact unit .
intros n0 n1 P P1.
exact (forall H : n1 = n0, P1 (f_equal S H)). Defined.
Definition no_confusion (n m : nat) (H: n = m) (P : n = m -> Set) : method n m H P -> P H.
intros n m H; case H.
case n ; simpl ; trivial.
intros; apply (H0 (refl_equal n0)). Defined.
Definition dep_eq_swap :
forall (S : Set) ( x y : S) (H: x = y) (P : x = y -> Set ), (forall H' : y = x, P (sym_eq H')) -> P H .
Proof.
intros S x y H; case H.
intros P H0.
apply (H0 (refl_equal x)).
Defined .
Definition finsplit (n m: nat) (i : Fin (n + m)): FinSum n m i.
intros ; induction n.
exact (is_inr i).
cut (forall (n':nat) (i' : Fin n') ( H : n' = S (n + m)), (eq_rec n' Fin i' (S (n + m)) H ) = i -> FinSum (S n) m i) .
intros ; apply (H (S ( n + m)) i (refl_equal (S (n + m)))); trivial.
intros n0 i' ; case i' .
intros n1 H.
apply (no_confusion (S n1) (S (n + m)) H (fun H => eq_rec (S n1) Fin fz (S (n + m)) H = i ->
FinSum (S n) m i) ) ; simpl. intros . clear H. apply (dep_eq_swap nat n1 (n + m) H0 (fun H => eq_rec (S n1) Fin fz (S (n + m)) (f_equal S H)
= i -> FinSum (S n) m i) ).
clear H1; clear H0.
intro H'; case H'; simpl.
intro H ; case H.
exact (is_inl fz).
assumption . intros n1 f H.
apply (no_confusion (S n1) (S (n + m)) H (fun H' => eq_rec (S n1) Fin (fs f) (S (n + m)) H' = i ->
FinSum (S n) m i) ); simpl. intros. apply (dep_eq_swap nat n1 (n + m) H0 (fun H2 => eq_rec (S n1) Fin(fs f) (S (n + m)) (f_equal S H2)
intro H'.
generalize f; case H' ; simpl.
intros f0 H2; case H2.
elim (IHn f0).
exact (fun i0 => is_inl (fs i0)). exact (fun j => is_inr j). trivial .
Defined.
Best,
Rawle.
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
- [Coq-Club]Defining function with dependent structure in goal, rcp
- <Possible follow-ups>
- Re: [Coq-Club]Defining function with dependent structure in goal, rcp
